#31 | |
But with the first version on the HD camera, there was no ROM version page to display so you couldn't initiate a package update. Now that the camera has that page, it might work like you are saying for any future updates. -gb- |
#32 |
Power Issue During The Install:
I used fully charged batteries for each camera during the firmware update. You never know when the power could go out or have some kind of brief disturbance! So, a fully charged battery is more than enough to do the complete firmware upgrade. Another firmware benefit: This firmware has impoved the camera's communication with the BP-GL65 Battery Pack on displaying the accurate amount battery life remaining. |
#33 | |
I've just confirmed using the FCP scopes that Zebra 2 is 100IRE, and that at least Cine3 brings everything to exactly 100IRE and no more, which is different than what it did before. Also, DCC does not activate anymore in Cine3 at least, and I assume all the Cines. Makes sense, goes along with the "no knee" behavior that is now the case also.
My Work: nateweaver.net |
#34 |
Dagnammit, any XDCAM SD owners around here? ;-)
#35 | |
Thanks for clearing that up, Nate. -gb- |
#36 | |
Contributor
Carroll Lam |
#37 |
Yep Carroll. right package. The camera won't recognise the firmware unless it is the correct one.
Been there done that. If there's a problem to be had installing firmware I'm usually the one to find it! Once I find the solution I'll post it here. |
#38 | |
Telecam Films
I am about to try the upgrade on my 510. Which file needs to be installed first, the ROM or the PKG File? I have the steps to follow on how to upgrade to the PKG but nothing on the ROM. Any more info on your end? Thanks Thierry. |
#39 |
Hi Thierry,
Strictly speaking the Package file should be installed first. Although I have done the AT as an experiment with no ill effect. But yeah, package file first, and then the AT. From Clives description you need to disconnect the lens connector and audio, and manually close the lens off. He said that it takes around 20 minutes for the package to upgrade, and that at one point the LCD will go blank, but the viewfinder will still display the update progress. AT should only take a minute. Let me know how you get on. The guys at Sony upgraded their 510 successfully, so it might be my memory stick that has a problem. |
#40 |
Can anyone share the upgrade procedure for the F70 or F30 Deck? I have a F30 deck that I would like to upgrade the firmware in but I don't have the service manual.
Thanks |
#41 | |
Telecam Films
Thierry. |
#42 | |
Telecam Films
Bellow is a link to download the instructions from our web site as a PDF file. www.telecamfilms.com/tech/pdw-f70update.pdf Enjoy! Thierry. |
#43 |
Thierry,
Thanks, that worked perfectly. There is a rather long part of the update that the LCD screen is just flickering, but it did complete and is working fine on the new firmware. |
#44 |
330 firmware
Has anyone updated their 330 firmware?
Is this a user upgrade or will we void the warranty if it messes up? Is there a clear discription of the correct way to do this? This doesn't really tell me much http://195.2.37.154/indexes/pi/EB/Oct_2006/00042538.pdf I did grab the files from here PDW-F330/F350: Package V1.56 + AT V1.56 + FRESH V1.05 thanks |
#45 |
Figured it out..... < "Now that wasn't too hard" >
Grin |
