Sony XDCAM HD -- various topics - Page 3 at DVinfo.net
Old January 22nd, 2007, 04:00 PM   #31
There's two SD formats in XDCAM, DVCAM and IMX.
If the disc is SD DVCAM, then the 350/330 will play it. If it's IMX, it will not.
The PDW-V1 disc reader will read both formats (but not XDCAM HD!).
My Work: nateweaver.net
Old January 22nd, 2007, 11:03 PM   #32
Working With Both 330s & 350s
If both the 330 & 350 have the same exact lens and are side by side
aimed at the same thing, and are both completely reset, they DO NOT
MATCH; colors, blacks etc are a little different.
With both models updated with the most recent firmware,
the menus and default setting are a little different making things
a bit difficult to match up. Anyone else having this issue?
Rob Stiff is offline   Reply With Quote
Old January 23rd, 2007, 11:56 PM   #33
Lenses with Zoom / Focus Display
Hi,
I know that with some lenses you have a readout in the display for zoom / focus.
I think this is extremely helpful - I do some wedding filming as well and I often have to pan back to bride/groom (fast!). Using the readout is easier than focussing by eye again.
At the moment I am thinking to purchase a "budget" Wide Angle SD Lens , so I ask myself generally how I can see with all the fujinon and canon products if they transfer the zoom/focus data?
Any comments on that?
thanks
ULI
Uli Mors is offline   Reply With Quote
Old January 24th, 2007, 07:56 AM   #34
SONY tips for better shooting
In the link section I found a sony page with
http://bssc.sel.sony.com/Broadcastan...tingTips.shtml
Reading some of these pdfs gives the impression that menus of XDCAM SD cams (530 etc.) go much further into detail than pdw-f330 / 350 can.
(example: "crispening" function and others)
I am wondering why they did not implent this into xdcam hd.
Any suggestions?
ULI
Old January 24th, 2007, 03:32 PM   #35
Yep! We already have those on the XDCAM forum.
Ivan Snoeckx is offline   Reply With Quote
Old January 26th, 2007, 04:13 PM   #36
XDCAM and Final Cut Express
Hi there,
One of my clients wants to try and edit my xdcam hd files via Final Cut Express. He has v3.5. Any idea if it has the necessary codecs?
Also, if they do not, any idea what is the best codec to convert it to?
Max
Max Kaiser
Director, Hand Crank Films
http://www.handcrankfilms.com
Max Kaiser is offline   Reply With Quote
Old January 27th, 2007, 03:27 PM   #37
From what I know FCE can only edit DV or HDV files. So you might want to capture via a XDCAM HD deck directly to HDV, for the best resolution/quality. If you capturing via the Firewire connection on cam, then DV is the only option.
Vincent Rozenberg is offline   Reply With Quote
Old February 1st, 2007, 02:00 PM   #38
FujiFilm now makes XDCAM discs.
http://www.4rfv.co.uk/industrynews.asp?id=58942
Paulo Teixeira is offline   Reply With Quote
Old February 8th, 2007, 09:17 AM   #39
Fianl Cut Pro work flow with XDCAM HD
I've been looking around for about half an hour, and haven't found what I'm looking for.
Can anyone point me to a description of the FCP work flow with XDCAM HD? I realize I can ingest through the HD-SDI connections and change codecs, but I'm looking for a description of using Sony transfer software, and editing native mpeg hd.
Tim Allison is offline   Reply With Quote
Old February 8th, 2007, 09:28 AM   #40
This is what you're looking for: http://bssc.sel.sony.com/Broadcastan...whitepaper.pdf
probably same file on Apple's FCP site here: http://www.apple.com/finalcutstudio/...whitepaper.pdf
Andy Mees is offline   Reply With Quote
Old February 10th, 2007, 07:52 AM   #41
Master Back Onto Xdcam - Avid Xpress Pro/vegas
Hello,
I have a (quite silly) question concerning mastering back onto xdcam.
I have got Avid Xpress Pro and Sony Vegas but on the first sight I am not that happy with the Vegas system. The thing however is, that Avid doesn´t support mastering back onto XDCAM at this stage.
So what I wanted to ask is whether there could be a way of importing XDCAM HD media into Avid, edit the thing on the AVID and then export as an MXF file, import MXF on Vegas again and then master back onto XDCAM. This may sound absolutely ridiculous in terms of "good workflow", I know but it was just a thought of a possible workaround. Hopefully Avid will support XDCAM HD mastering soon anyway and I will however things go have to upgrade to Media Composer or completely switch to FCP. But for the moment I´m looking for a complicated way to make a useable master copy. I´m also thinking of buying a blu-ray burner and export the thing on a blu-ray disk.
What do you think?
Thanks a lot for your thoughts,
Emanuel
Emanuel Altenburger is offline   Reply With Quote
Old February 12th, 2007, 11:33 AM   #42
There have been discussions on the Avid forums that the new version of Avid Xpress Pro and Media Composer will both support mastering back to disk. The demo version is out among those who are testing the software. I don't know what the final release will bring, but I would hold on for a while and you may be pleasantly surprised.
Bob Willis is offline   Reply With Quote
Old February 16th, 2007, 08:52 AM   #43
Xdcam Discs
Will older XDCAM DISCS work in the 330 & 350 cameras?
Old February 16th, 2007, 09:40 AM   #44
Simple answer: Yes.
Old February 20th, 2007, 07:10 AM   #45
Storage XDCAM HD clip
I am new in this forum so I am grateful to be welcomed here.
I come from DVC Pro and Avid world, but I intend to move to XDCAM HD ( F 350 ) and also FCP, but I am unfamiliar with it.
I have 2 questions concerning FCP :
- Could you store a stereo or 5-1 clip edited with FCP on a XDCAM HD disc ?
- if your goal is to produce Blue ray and SD DVDs from a clip mixing DVC PRO and XDCAM HD shots, is it possible with FCP ( no problem with Media composer ) ?
Thanks for your help.
Alain Gerente is offline   Reply
