DXF-20W viewfinder problem for PDW-f350 at DVinfo.net
Old October 29th, 2011, 10:03 AM   #1
Hi
My DXF-20w viewfinder for my Sony PDW-f350L is causing me some problems. I seems that the right hand vertical portion of the Band W screen has been squeezed in. So, when I look through the viewfinder, the right hand side of the image looks like it has been keystoned (or squeezed) in by about 3/4 of an inch. This throws off my framing and actually distorts that side of the B&W viewfinder image. The recorded image on the XDCAM disk and the color flipscreen look fine, so it seems it is definitely an issue with the viewfinder.
Has anyone seen this happen before? Is there any way that you can electronically move or size the image on the B&W screen of your viewfinder? Cannot seem to find a way in the menu (or anywhere else) to customize or move/stretch the image on the B&W viewfinder.
I would really appreciate any help on this
TC
Tristram Clark is offline   Reply With Quote
Old October 29th, 2011, 10:54 AM   #2
Vortex Media
Re: DXF-20W viewfinder problem for PDW-f350
Have you considered the possibiiilty that it is just plain broken? There's no menu that is going to compensate for that kind of distortion. Do you have access to another VF that you can swap it out with to compare? Sounds like it needs a trip to the hospital for repair. :-(
Old October 31st, 2011, 02:11 AM   #3
it appears to be a common problem with that viewfinder, I bought a spare one so I can quickly swap while the other one has a tiny transistor replaced (same problem as yours)
I bought the service manual for the viewfinder but could not narrow it down myself
Anton Strauss
www.videoproductions.com.au
Anton Strauss is offline   Reply With Quote
Old October 31st, 2011, 04:14 PM   #4
A strong magnet in the vicinity of the viewfinder (which is a small cathode ray tube) could also cause this problem. Headphones ?
Old October 31st, 2011, 10:36 PM   #5
according to the tech who fixed mine
most likely cause, turn off camera and turn on camera with no pause, such as when making a menu change that requires restart
and I must admit, I did that many times
Anton Strauss
