How to give client Windows hard drive from XDCAM discs at DVinfo.net
Old May 5th, 2011, 01:17 AM   #1
Shot a program for client on XDCAM PDW-700 and we edited in FCP. They want back up files delivered in Windows compatible files. I have 2 windows computers. Can I use any Sony software to take the XDCAM discs with my reader to lay those off to a windows hard drive that they can use?
Seems like a simple question.. just want to make them happy.
They say that they can use MOV files that I already have.. just need to get them to a Windows formatted drive. Maybe there is a utility to take a MAC drive to make it readable to a Windoz system?
Thank you,
George
George T. Griswold, Jr.
www.videonow.info New Orleans
George Griswold is offline   Reply With Quote
Old May 5th, 2011, 06:10 AM   #2
Re: How to give client Windows hard drive from XDCAM discs
Mac users send me ProRes files on a regular basis and I can use them fine in Windows
I wish it worked as simple the other way around, Windows users should be allowed to use the ProRes codec to convert windows files for Mac use, but this is not the case
they will not be able to use the native MXF files unless they have editing software such as Edius
also, they will not be able to see anything on a Mac formatted hard disk unless they purchase Macdrive8 for windows
Anton Strauss
www.videoproductions.com.au
Anton Strauss is offline   Reply With Quote
Old May 5th, 2011, 06:25 PM   #3
Telecam Films
Do you know what edit app they will use on the PC? Some editing apps may not be able to read .mov XDCAM files rewrapped by FCPro. In any case, it is best to send them the XD material in its native form with all the metadata that was on the discs. In order to do so:
1. Install the PDW-U1 Driver (that's the reader you have right?) to your PC. Free download here:
https://www.servicesplus.sel.sony.co...del-PDWU1.aspx
2. Connect the PDW-U1 to your PC
3. Insert XDCAM disc
4. Disc will mount as a storage device and will show up in "My Computer"
5. For each XD disc you want to sent to your client, create a folder on the storage device. Your can name them Disc 1, Disc 2, etc... I often append XDCAM HD420 and frame rate to the folder name so the content is obvious.
6. Drag the entire content of each XD disc in each of the discs folders you have prepared
Best,
Thierry.
Thierry Humeau, DoP
Télécam Films
www.telecamfilms.com
Thierry Humeau is offline   Reply With Quote
Old May 15th, 2011, 01:20 PM   #4
Thanks Thierry- I did what you suggested. Involved re-importing, but was ultimately more dependable.
George
