Can Not Change Master Black at DVinfo.net
Old April 27th, 2011, 06:23 AM   #1
Not sure whet I am doing wrong but I bet it is simple. I can not change my Master Black off 0.
Using HG 2
Gamma is on
Paul Cronin
www.paulcroninstudios.com
Old April 27th, 2011, 10:26 AM   #2
Re: Can Not Change Master Black
I know on my pdw-350 sometimes i had to spin the dial way more than i thought i would have to. I know it doesn't make sense but give it a try.
www.marshallstaton.com
Marshall Staton is offline   Reply With Quote
Old April 27th, 2011, 12:17 PM   #3
Thanks for the input Marshall I will give it a try.
Paul Cronin
Old April 27th, 2011, 01:07 PM   #4
You were spot on Marshall. It takes three full turns to go from 0 to -1.
Thank you Marshall
Paul Cronin
Old April 27th, 2011, 01:31 PM   #5
That is the only setting that takes a while for this to kick in. I wonder if it's Sony's way of saying that they don't want us to change this!
Cheers
Old April 27th, 2011, 01:36 PM   #6
Strange but that could be it. For the new scene file I sent you can change the Master Black now to -2.
Paul Cronin
Old April 28th, 2011, 01:07 AM   #7
be aware that the setting is effective also "between" 0 and "-1" - each single step of the rotary know lowers (or lifts) the black a bit. Its a matter of not showing values between thousands but -99 to +99...
Uli
Uli Mors is offline   Reply With Quote
Old April 28th, 2011, 05:46 PM   #8
No sure what you are saying. -2 seems very nice in most outside shooting light.
Paul Cronin
Old April 29th, 2011, 12:32 AM   #9
Hi Paul,
-2 is fine. I just wanted to claim that all "steps" BETWEEN single values (0, 1 etc.) already take effect.
