XDCAM Transfer on Mac at DVinfo.net
Old July 16th, 2010, 12:59 AM   #1
Hi,
up to now you had to install FCP for HiRes Viewing/XDCAM Transfer Tool.
Is that still the case?
Is there nowadays a way to run XDCAM Transfer + PDW700 (or so) without having FCP installed?
ULI
Uli Mors is offline   Reply With Quote
Old July 16th, 2010, 02:33 PM   #2
I noticed there is a checkbox in XDCAM Transfer's preferences labeled something like 'Import clips with no codec', so presumably you can still use the Transfer tool to re-wrap to mov without FCP.
Daniel Wright is offline   Reply With Quote
Old July 16th, 2010, 04:31 PM   #3
No codec or use XD decode
Hi there - the previous poster is correct - you can use the 'no codec' option but you can also buy the XD decode codec from Calibrated Software, which lets you preview your clips without having to have FCP installed.
Calibrated Software
Dave
Dave Chalmers is offline   Reply With Quote
Old July 17th, 2010, 11:28 AM   #4
Maybe you can try this http://blog.lib.umn.edu/mcfa0086/dis....component.zip
Haven't try it my self but I will be glad to know if it works.
Olakunle Olanrewaju is offline   Reply
