XDCAM PDW-F800 power supply at DVinfo.net
Old May 12th, 2010, 06:14 AM   #1
I need to buy or rent a power supply for a shoot. The shoot is 4 hrs non-stop so I will be using disk cache exchange and will not be able to switch batteries.
My Switronix charger only goes up to 50w.
What are people using on the f800 as a 120V power supply?
Paul Cronin
www.paulcroninstudios.com
Old May 12th, 2010, 11:06 AM   #2
My IDX charger has a DC output. I would just connect an XLR cable between the charger and camera.
Old May 12th, 2010, 11:59 AM   #3
Hi Tom,
Understand IDX charger just a power supply. I have a Switronix charger that also has a power supply but only 50w and I am told by people at Sony that is should be minimum 100w.
Paul Cronin
Old May 12th, 2010, 12:48 PM   #4
Solved the power supply problem thanks
Paul Cronin
Old May 12th, 2010, 01:59 PM   #5
I'm looking for the cable that goes between my Sony V mount DC battery charger and my Sony F350. It is a 4 pin connector both on the power supply and camera. Where can I get one from?
I need this as I do some long gigs where I cannot change batteries during the shoot If I'm the only camera.
Cheers
Old May 12th, 2010, 03:41 PM   #6
@ simon: It's a 4 pin xlr connector. Look it up at this site sponsors like B&H.
Vincent Rozenberg is offline   Reply
