Vortex Media
Vortex Media's PDW-700/F800 Field Guide
I hope nobody is offended if I take a minute to announce that the book I’ve been working on since last fall for the F800/700 has finally started shipping this weekend.
Vortex Media's XDCAM Field Guides “Vortex Media’s PDW-700 and PDW-F800 Field Guide” is 320 pages, spiral bound (so it stays open), full-color, offset printed, and fully indexed. I’d say about 99% of the camera’s functions are covered, including a number of undocumented features and information that can’t be found in any of Sony’s publications. If I had known before I started how hard it was going to be, I never would have done it. But once I started, I didn't want to quit. In my opinion, the F800 and 700 are the most complicated commercially sold cameras ever built. It’s amazing what they can do, and how well they do it. Some people have written to ask me if there will be a DVD, and the answer is no. These camera's are too complicated to teach effectively in a DVD. It would either have to be a 10 volume DVD set, or be so superficial to be of no use to an experienced shooter. The book provides an easy-to-use resource any time and any place someone needs information. TABLE OF CONTENTS How to use this Field Guide Preface Parts Description . 2 Viewfinder Display 11 LCD Monitor Display 12 Thumbnail (Playback) Display . 13 Status Confirmation Screens 14 Menu Tree 16 Operation Menus . 16 Paint Menus 22 Maintenance Menus . 26 File Menus 31 Diagnosis Menus 33 Disc Menus . 34 Thumbnail Menus . 34 A Brief Introduction to XDCAM . 35 Highlights of the PDW-F800 AND PDW-700 . 36 Differences Between the Two Camera Models 37 25 Steps for initial Set Up and Quick-Start Guide . 40 Viewfinder, LCD Monitor, and Sub LCD Screen 55 Color LCD Monitor 55 Viewfinder Display . 57 Markers 59 Sub LCD Screen . 61 Status Confirmation Screens . 62 Batteries and Power . 63 Power conservation tips . 66 XDCAM Professional Discs . 68 Erase (Re-format) a previously used disc . 71 Disable the Format Disc command . 72 Check a Disc's properties and give it a name . 73 XDCAM Disc file structure . 75 Directories on an XDCAM disc . 76 Root-level files on an XDCAM disc 76x Menus Overview 77 Camera Menus 79 Menu navigation tips 83 Camera Menus tutorial . 84 The User Menu 86 Basic techniques for customizing the User Menu . 88 Insert a User Menu page . 89 Delete a User Menu page 90 Move a User Menu page . 90 Advanced techniques for customizing the User Menu 92 Create a custom User Menu page from scratch . 93 Add the new page to the User Menu 95 Reset the User Menu pages back to the factory default 97 Recording Formats . .98 Choose a Recording Format . 101 24P mode limitations . 101 Mixed Recording . 102 Custom Clip Naming . 103 Create a custom clip naming system . 104 Prefix data files for clip names 105 Using clip names for notes and logging 107 Assign Switches 108 Allowed switch assignments 109 How to program an Assign Switch 111 Explanation of all Assign Switch functions . 112 How to delete the last clip . 114 How to use Freeze Mix 117 User Assign (UA) switch options 120 How to program a User Assign switch . 122 SDI monitoring and Video output . 125 Configuring the SDI outputs . 127 Remote Trigger . 127 Test Out (composite video) . 128 Optional IN/OUT upgrades . 129 Audio . 130 Audio Monitoring . 131 Input source selection 133 Channel selection . 135 Recording levels . 135 Adjusting the shotgun input . 136 Adjusting Rear and Wireless levels with Front Dial 137 Manual recording levels for CH-3 & CH-4 . 138 Audio Menus . 138 Wireless Audio . 141 Wireless Audio menus . 143 Paint Menus 145 General philosophy . 145 Dynamic Contrast Control (DCC) . 147 Overview of the Paint Menus 148 Gamma 148 Knee 151 Detail 152 Skin Detail . 153 Matrix Linear 155 Matrix Multi 155 Saturation . 159 User Setting Data Files 160 Format a Memory Stick . 162 Jump to a specific page when Memory Stick is inserted 162 Locate files on a Memory Stick 163 USER Files . 164 Save a User File 164 Load a User File 165 ALL Files 167 Settings that are not saved with ALL files 169 Create an ALL file . 169 Recall an ALL file . .170 Reset the camera to factory-default values . 170 Store your own Standard Setup . 172 Reset back to the Standard Setup 172 SCENE files 173 Choose an onboard SCENE file 176 Save a SCENE file to the onboard memory . 176 Save a modified SCENE file to the onboard memory . 177 Reset a SCENE file . 177 Save a SCENE file to a Memory Stick . 178 Load a SCENE file from a Memory Stick 179 Load five SCENE files from a Memory Stick . 180 Save five SCENE files from a Memory Stick 180 Sony's sample SCENE files 181 USER GAMMA files . 182 Load a USER GAMMA file . 183 Select a USER GAMMA curve for shooting . 184 Delete the current USER GAMMA file . 184 LENS files 185 Save a LENS file 185 Load a LENS file 186 Reset the LENS file settings 186 Proxy files . 187 Enable automatic Proxy recording to USB . 189 Copy one Proxy file to USB . 189 Copy all Proxy files to USB 190 Format a USB device . 190 Delete all Proxy files on a USB device191 Metadata . 192 Clip Name 192 Time & Date 193 Timecode . 193 Thumbnail Images . 193 Clip Flags 194 UMID . 194 Planning Metadata . 194 Disc Name . 195 Technical Metadata . 195 ShotMarks (Essence Marks) 196 User-Defined ShotMarks . 197 Planning Metadata (for clip naming) . 200 Create a Planning Metadata file . 201 Configure a Planning Metadata file for Clip Naming . 202 End Planning Metadata clip naming . 204 Exposure 205 Auto-Iris 205 Auto-Iris Speed 205 Exposure Compensation . 206 Clip High Light . 207 Auto-Iris Window . 207 Customize the Auto-Iris Window . 208 Zebra . 209 Zebra Menus . 210 Zebra 1, Zebra 2, or both? 211 Gain 212 Shutter 213 Recommended Shutter Speeds and Time vs. Angle . 214 Set the Shutter Speed 214 Extended Clear Scan (ECS) 215 Slow Shutter (SLS) . 216 Hide/Show Shutter Degree Choices . 217 ND Filters 217 Focus 218 Peaking . 218 Focus Magnification . 219 Focus Assist 219 White Balance 220 Auto Tracing White Balance (ATW) . 221 Preset White Balance 222 Custom White Balance . 224 Shockless White 226 Advanced White Balance Controls . 227 CC Filter Memory . 227 Offset White . 228 Dialing in the Color Temperature manually 230 Black Balance 231 Timecode 232 Time Data monitoring . 233 Setting the Timecode . 234 Jam-Syncing the Timecode 235 Interval Recording (Time-lapse) . 237 Auto Interval Rec mode .237 Manual Interval Rec (Consecutive) mode . 239 Manual Interval Rec (Single Shot) mode 240 Picture Cache 242 Normal Picture Cache mode 243 Notes and Tips for Picture Cache 243 Disc Exchange Picture Cache . 244 Slow & Quick Motion . 245 Notes and Tips for S&Q Motion . 245 Shooting with S&Q Motion . 246 Warnings . 247 <!> Warning Indicator Lamp . 247 Customize the <!> Warning Lamp 250 Automatic Lens Aberration Control (ALAC) 252 Automatic Pixel Replacement (APR) 252 Back Focus 253 Bars & Tone . 254 Video Playback 256 Three methods of playing back the last clip . 256 Thumbnail Screen . 258 Tips for Thumbnail Screen navigation 259 Live & Play 260 Thumbnail Menus 260 Clip Information . 261 Select Index Picture . 262 Clip Properties . 262 Delete a Clip 263 Lock a Clip . 264 Set Clip Flag . 265 Filter Clips . 265 Skip Scroll 267 Expand Thumbnail 268 Chapter Thumbnail . 268 Essence Mark Thumbnail . 269 Clip Lists 270 Add Sub Clips 272 Change the Order of Sub Clips . 273 Trim the IN/OUT points of Sub Clips 273 Delete Sub Clips 275 Clip List playback 275 Save the Clip List 276 Disc Menus . 277 Explanation of all Disc Menus 277 Importing Clips . 281 Four methods of importing . 281 Benefits of the PDW-U1 282 XDCAM Transfer — for Final Cut Pro 283 Importing via File Access Mode (i.LINK) for Windows . 286 Importing via File Access Mode (i.LINK) for Mac 287 Importing via FTP Mode (Ethernet) for Windows 288 Importing via FTP Mode (Ethernet) for Mac . 291 Display the Disc and Clip properties in a Web Browser 293 Updating the Firmware 295 Notes 296 Index 299 Back focus chart . 305 Other products from Vortex Media 306 Quick Finder chart . 307
Vortex Media http://www.vortexmedia.com/ Sony FS7, F55, and XDCAM training videos, field guides, and other production tools |
Hi Doug,
Congratulations. Perhaps Paul could be your first customer. I suppose the PMW-350 might be nest on the agenda.? (statement and question).
David Issko Edit 1 Video Productions |
Vortex Media
David, due to an overbooked schedule this spring and summer, I don't have any plans right now to do anything for the PMW-350.
David, I am one of the first customers for the F800 book. Thanks Doug for all the hard work. I look forward to learning my new F800 with the help of your book. I will keep the book in my bag for the "How do I do this?" questions in the field.
My Vortex Media EX1 field guide lives in the camera bag and I pulled it out often. Last edited by Paul Cronin; March 21st, 2010 at 04:18 PM. |
#5 |
Congrats
Doug,
Thanks for all you hard work. Im sure this will be a great help for the 700/800 owners and would be owners. Can you sign my copy? |
#6 |
Vortex Media
Dennis, aren't you hosting a book signing with drinks and refreshments in your suite at the Hard Rock while we're at NAB? That was my understanding. I 've already sent out invitiations to 500 close friends.
#7 |
D,
Cats out of the bag. Yes there will be entertainment as well, so only bring wives of liberal (M)ilk. |
#8 |
Perfect the ad comes out on the NAB home page this week.
#9 |
Telecam Films
Fantastic! Eager to get it. Thanks for the hard work.
Thierry. |
#10 |
Great Guide/A must own
Doug,
Just did my first pass with your 700/800 guide. This is a must for all owners. As you state from the start, " If the PDW-700/800 aren't the world's most advanced commercially sold cameras ever invented, Then I'd like to know what is." It has been the bane of my existence to help other operators and post facilities to know just some of the basic functions of this camera and what to do with the files pre/post acquisition. The layout is easy to follow, and issues can be accessed quickly. Almost a book in a PDF form. Great job. I highly recommend this for anyone considering buying a 700/800 XDCAM. And if you already have the camera, it is a must if you want to wear the title as owner/OPERATOR !!!! |
#11 |
First Class Work
Doug your 700/F800 field guide is excellent thank you! This book will help push me up the learning curve so much faster, and to a level I would not achieve on my own. I agree with Dennis a must for any 700/f800 camera owner.
#12 |
Very detailed masterpiece
Hi Doug,
I just finished going through your field guide for the PDW-700 and PDW-F800 XDCAM HD422 cameras. In this book is put a lot of work! It’s not just a copy from Sony’s operation manual with some features added. No, this field guide is the most detailed piece I have ever seen for such high-end professional cameras. It just covers everything. I can’t think of anything what is not said about these cameras in this well documented book. Explanation for some functions goes much further then the operation manual from Sony. It’s a walk through the whole Professional Disc concept from start to end without getting bored with unnecessary and useless information. It also contains lots of warnings, notes and tips for setting up these cameras. These with pictures illustrated tutorials of camera settings make it a breeze to use in the field. The book itself is small enough so that it fits in every camera bag. This makes that there isn’t an excuse for not carrying it with you. Each page is color-coded so that navigating through this guide is very fast and simple. Because there is a small difference in some camera menus between the two models, a very easy menu numbering system, that always is printed in bold, leads you directly to the menu of your choice. The print quality of this book is also superb! I completely agree with Dennis Dillon and Paul Cronin that this guide is a must have for all PDW-700 and PDW-F800 operators and future owners of these cameras. Sony should put it as an accessory on their website, brochures and manuals! Great job Doug, thank you! |
