LASER into CCD at DVinfo.net
Old March 19th, 2010, 04:29 AM   #1
LASER into CCD
HI,
when filming events with Lasers (Lasershow etc.) - is there a way to avoid damage?
ULi
Uli Mors is offline   Reply With Quote
Old March 19th, 2010, 11:04 AM   #2
Don't film into the beam!
Try to shoot so that the laser source is is pointing away from the camera. Shooting a beam from the side of a beam pointing away from you should be fine, it's only if the beam is directed into the lens that you may have an issue.
Old March 19th, 2010, 11:42 AM   #3
This may be totally wrong, but ya gotta believe that if they can shine a laser into people's eyes--that fan kind of effect?--its got to be of short duration and low power. I'd think that kind of beam wouldn't hurt a camera.
Good luck and let us know how it turns out!
Hmm. Just thought of something. Lasers work with persistance of vision-like TV portraying motion out of still images. The light of a moving laser may be very dim. And will likely not show the entire lasered image--might want to use a slow shutter.
Andy Tejral
Railroad Videographer
Andy Tejral is offline   Reply With Quote
Old March 20th, 2010, 03:19 PM   #4
If you read the instruction manual of the camera it clearly states not to shoot a laser. I did once (before reading the manual ofcourse) and it did not damage the ccd. But I would not take the risk again.
http://dl.dropbox.com/u/2332151/laser1.jpg
XDcamHD F330, 2" VF, Fujinon 13x3,3. 550D, MagicLantern, CS5.5
www.picturethis.tv
Eelco Romeijn is offline   Reply With Quote
Old March 22nd, 2010, 09:20 AM   #5
well, just to let you know - I´ve already filmed Laser Shows (concerts + laser, weddings + laser, events+laser) with PD150, Z7, EX1 + pdw-F350, no damage yet. And of course, letting the laser "wall" wipe over you and the cam (frontal!) is a great effect...
I know that the laser can damage CCD/CMOS , and always thought: is there a way to 100% avoid serious damage when a laser hits the CCD? ND ? Was I just lucky?
Or simply have a 300$ cam with me for not getting the production camera broken??
ULI
