export xmf files from adobe prem to 330 camera at DVinfo.net
Old September 8th, 2009, 08:10 PM   #1
i have just got a 330 and need to edit files then export back to disk - in camera (edit using pem pro & main concept)
what is th best way to export back to the camera?
ta
greg
Greg Waite is offline   Reply With Quote
Old September 9th, 2009, 01:00 PM   #2
It's been a while since I used main concept, but if I remember right you have to export your clips as XDCAM MXF's from main concept to your hard drive then connect the camera using FAM mode and copy the MXF's to the clip folder of the XDCAM Disc. If you have problems try using the C****.MXF file naming convention, so your fist clip would be C0001.MXF then C0002.MXF and so on.
Old September 10th, 2009, 08:05 AM   #3
Export xmf files
Thanks alistar,
tried that but i could not copy to the clip folder on the disk - could copy to other folders but not the clip folder - tried new disk and c*** numbering but to no avail....
Can't find anything in the manual about it ?
Greg
Old September 10th, 2009, 12:06 PM   #4
was .MXF in capitals? it must be all capitals.
Other things to check:
The disc must be blank or only contain files of the same format as the ones you are trying to write.
The camera must be set to the same format as the files you are trying to write, eg 25P HQ or 50i HQ etc.
Old September 10th, 2009, 08:37 PM   #5
Still no luck alister,
have done all that - new disk, check caps etc and i come up with message "the file or directory is corrupted and unreadable"
any other suggestions
ta
greg
Old September 11th, 2009, 12:33 AM   #6
How are you writing to the disk? You have to write to file from mainconcept to a local hard drive or your desktop. Then copy the file to the XDCAM disk. You cannot write directly from mainconcept to the XDCAM disk.
Beyond that I'm really at a loss.
Old September 11th, 2009, 02:41 AM   #7
I a writting to hard drive (edit folder) then trying to transfer to camera?
Thanks for your help..
Greg
