XDCAM audio problem in Vegas Pro 9.0a at DVinfo.net
Old July 26th, 2009, 06:36 PM   #1
Taken away too young... rest in peace Eugene
Just wanted to pass on this caution to anyone here using the new Vegas Pro 9.0a for their NLE with XDCAM clips:
I'm editing XDCAM SD (DVCAM) MXF files. I have clips that are one to two hours long. I discovered that with any of the clips, I will lose a full 15 frames of audio (one GOP) at the following places: 08:55:03, 26:35:10, 44:15:38, and probably others at the same interval multiples.
The audio is gone both in terms of actual sound and in terms of waveform at those points. There may be a slight video glitch there as well, but I couldn't tell since my footage available to test was a talking head without much movement. But I can say in general the video part wasn't missing or anything like that.
I tried this with multiple clips and the dropouts are at the exact same spots.
I verified that rendering out those spots showed the audio dropouts.
I tested the same original clips in the Sony XDCAM Viewer and in Vegas Pro 8.0c, and there was NO missing audio in those spots.
I haven't been able to reproduce this with XDCAM HD MXF clips, only with XDCAM SD (DVCAM) MXF clips.
I'm reporting it to Sony Creative Software, it's a very similar bug to the problem that was in Vegas Pro 8.0c with these same MXF formats till they fixed it with a pair of new dlls.
Scorpio Productions
PDW-F335, PDW-U1, Vegas Pro 9.0b
Eugene Kosarovich is offline   Reply With Quote
Old July 27th, 2009, 01:00 AM   #2
Thanks for the heads up.
One small point is that DV does not use GOP's, it is I frame. So the reason for a 15 frame hole is probably due to something else.
Old July 27th, 2009, 03:58 AM   #3
Opps, good point! When I saw 15 frames, I was instantly thinking the MPEG-2 GOP length from HDV, which I think is the same length in XDCAM HD.
Thanks for the correction. :)
Scorpio Productions
Old July 27th, 2009, 06:46 AM   #4
Images: 10
This sounds like the same problem Vegas 9 has with XDCAM 422 codec. It will not import audio properly, nothing but a series of white noise.
Old July 27th, 2009, 07:18 AM   #5
I shot a wedding in 60p had the same problem with Vegas 9 with my EDCAM EX footage..
Old July 30th, 2009, 06:15 AM   #6
Hi,
I forwarded this report to R&D in Madison, but didnt get a reply yet.
IŽll keep you updated.
Regards
Uli
Uli Mors is offline   Reply With Quote
Old August 28th, 2009, 10:21 PM   #7
Vegas Pro 9.0b lists this bug as fixed. And so far my tests confirm this. Note that this is only the XDCAM SD (DVCAM-mode) one that I'm talking about, not the ones others mentioned.
Scorpio Productions
Old August 30th, 2009, 02:25 PM   #8
Thanks for the update Eugene.
Alister Chapman is offline   Reply
