PDW700 FCP import, gray bars on index icon and export to picture
Hi all,
I have imported my footage from the camera via XDCAM transfer, and already started to edit my piece. However, all my bin icons of the clips has 1 horizontal thick gray bar and 2 thinner lines running vertically, thus making it recognizable. I also have found out, if I export via Quicktime export, it makes these bars as well. Anybody familiar with this problem? Thanks in advance, Takeshi |
I have not seen that specific issue. I would make sure you are running the latest version of XDCAM Transfer(2.9) and if you are running Final Cut Studio.... your version needs to be 6.0.3 or above if it is the newer HD422 codecs. Support for the newer codecs came with the Final Cut 6.0.3 update. I would update these and make sure your capture/sequence/output settings all match up with the native footage. Using Easy Setup in FCP and match with the XDCAM HD flavor is probably the easiest way to do this.
More information is needed here to better help you. The codec, NTSC or PAL, bit rate and frame rate of the clips. It could be firmware versions of the camera/deck. Are you using KONA or Decklink settings? |
Thanks for your input.
I have shot MPEG HD (HQ) mode, I am editing with a FCP 6.05. I am not having trouble editing or Exporting Quicktime. The icons in FCP, the export via Compressor Quiktime transfer, (? I am using japanese version, so I don't know what the actual wordings are...) and even the icons in "Finder" have these grey bars,,, http://dl.getdropbox.com/u/496685/picture7.png Very strange. I don't have a disk reader nor camera here, so I think I will continue working like this, since I can evade the problem. Last edited by Takeshi Fukushima; May 26th, 2009 at 02:04 AM. |
#4 | |
Takeshi
This is because you must have downloaded and installed the trial version of Calibrated Software's XD Decode codec. This is not intended for use on FCP systems as is noted on their website. Calibrated{Q} XD Decode Quote:
Best Andy |
#5 | |
THanks Andy!!
>>DEMO LIMITATIONS That description exactly matches my problem! I have searched my system to find a Calibrated{Q} software I DO NOT remember downloading nor installing... I have transfered my footage via XDCAM transfer, and open them in FCP. I don't see how Calibrated{Q} could have come in to the process... I have uninstalled it, now hopefully everything will be normal for once... Do I have to re import everything you think? Thanks again!!! So glad to know what the problem is! Takeshi Quote:
#6 |
Andy,
Just to report that I've restarted my system and everything is a-okay! No Grey marks! You can't imagine how relieved and happy I feel now. I had no idea what the problem was and it was driving me nuts!! Thanks again!! Cheers, Takeshi |
