problem scaling HD to SD at DVinfo.net
Old September 25th, 2008, 11:34 AM   #1
problem downconverter HD to SD
Hello again, I have a problem scaling HD to SD, the contours are jagged, especially in parts of high contrast and definition is lower than in DVCAM, more blurred, there is some solution, working with the detail 0 HD.
Thank you very much.
Alf Salva is offline   Reply With Quote
Old September 28th, 2008, 02:36 AM   #2
If you downconvert HD footage in the camera in AVC mode, you can select the amount of SD detail in the menu. Page 5 of the paint menu. There's Hi/Med/Low.
This affects the downconverted detail only.
In my experience there's no noticable difference between shooting HD and capturing SD compared to shooting SD and capturing SD.
XDcamHD F330, 2" VF, Fujinon 13x3,3. 550D, MagicLantern, CS5.5
www.picturethis.tv
Eelco Romeijn is offline   Reply With Quote
Old September 29th, 2008, 07:50 AM   #3
The problem is when you become a project in HD SD, when the NLE to scale the HD dv, the edges of the images are bright and stepped losing resolution, if it turns the camera is perfect.
Thank you
Old September 30th, 2008, 07:12 AM   #4
Hi Alf,
Can you tell us which NLE you use? And on what platform (Windows or Mac) ?
My current workflow for HD--> SD is (on Windows with Premiere CS3):
Export from Premiere CS3 to Debugmode Frameserver --> Start VirtualDub and open the frameserved AVI file.
In Virtualdub I do the scaling to SD using Lanczos3, use interlaced if source is interlaced, compression Blackmagic 10Bit 4:2:2 (I have a blackmagic card). Then in Encore I do a transcode to DVD. The end result is very nice.
Richard
Panasonic AF101, Various Nikon Primes and zoomlenses
Richard Raaijmakers is offline   Reply With Quote
Old October 1st, 2008, 01:58 PM   #5
I use NLE Edius Broadcast 4.6, windows.
Thank you
Old October 1st, 2008, 02:20 PM   #6
There is a known problem using Edius to encode directly from an HD timeline to SD output, and there are two basic workarounds:
(1) before doing the SD render change the project setting to widescreen SD and check your titles and effects for proper alignment before rendering.
(2) render an HD output file from the HD timeline, then pull that into a blank widescreen SD project to render the SD output.
Basically, the Edius encoder doesn't do well at processing HD directly to SD, but if you use an SD project setting it breaks that process up into two steps which the encoder handles better. For an even more detailed workaround with superior results see the Edius forums at Editing with EDIUS - Forum Index
Old October 2nd, 2008, 12:46 PM   #7
The main problem is the phased appearing in the profiles of bright images that burns my f-350 XDCAM HD to move from SD to HD with my NLE Edius Broadcast.
thanks
