Hire of prime lenses/adapter in UK at DVinfo.net
Old July 9th, 2008, 12:49 AM   #1
Anyone know if you can hire a suitable adapter and prime lenses for the F350 in the UK? I'm thinking of having a go on a future project.
Paul.
Paul Gale is offline   Reply With Quote
Old July 9th, 2008, 01:48 AM   #2
What sort of primes are you after? The Sony 2/3" adapter is readily available and means you can put Canon cine primes or Zeiss 2/3" lenses on it. Or do you mean Nikons etc.?
Steve
Old July 9th, 2008, 02:04 AM   #3
TBH, I'm really not sure - just wanted to get a great shallow DOF.
What lenses are most available for hire and give the best results?
This is a whole new area I need to get up to speed with :)
Paul.
Old July 9th, 2008, 02:12 AM   #4
The depth of field of a prime lens is the same as a zoom at the same focal length and aperture. The only way to get 35mm-type DoF is with one of the adapters from Redrock/Letus etc. that optically convert them (never used one myself) - presumably that's what you're after. Do a search on this forum under Letus - I think there may even be a sub-forum about them.
Also I believe Phil Bloom is a bit of an authority - check his website www.philbloom.co.uk
Steve
Old July 9th, 2008, 02:21 AM   #5
Yes thanks Steve, I've read everything on here about the Letus and spoken to Phil in the past.
What I was after is if there's a hire outlet for either these or the other alternatives to the Letus (P+S Technik)?
Thanks.
Old July 9th, 2008, 03:00 AM   #6
Have you tried Visual Impact? They are probably the best bet. Also www.axisfilms.co.uk has a Pro35 listed for hire.
Steve
Old July 9th, 2008, 03:01 AM   #7
Thanks - will enquire...
Old July 9th, 2008, 02:25 PM   #8
If you want a 2/3" adapter I have one.
Old July 9th, 2008, 02:35 PM   #9
Thanks Alister, much appreciated.
After ringing around, a couple of people recommended an adapter with the Pro 35.
Any experience of the Pro35 at all?
Cheers,
Paul.
PS let me know how the shoot went...
