xdcam transfer 2.5.1 for mac
already posted in the EX forum by Craig, but worth reposting here for those of us not using the newer EX
http://www.sony.ca/xdcamex/software.htm |
Should be up on the US site as well. Fixes XDCAM Transfer ability to recognize time code shot using clock.
And for me... a NEW Prodisc driver which is fully Leopard compatible. Yes, your disc icon now appears on the desktop and finder as it should. Yeah! -gb- |
#3 | |
In Scenario 1 if you choose "Look", to rescan for the targeted directory and that directory is still not found then you are now prompted by a second dialog that you must reset the import location preference. Much better, although I'd still prefer the single dialog with "Cancel", "Reset..." and "Rescan" options, but I guess thats just me. For Scenario 2 however nothing has changed. If you launch the software without the targeted cache location mounted then the software will still arbitrarily reset the cache directory to the default (~/Library/Application Support/Sony XDCAM Transfer) without any warning that it has just happened. The new setting will persist until you manually change it again. Ah well, its certainly a move in the right direction, tho' I'd love a bit more polish on these unnecessarily rough edges in a minor point release update. Still a work in progress I hope. My wish list for XDCAM Transfer 3.0? 1) Ability to name sub-clips in the logging tab, surely equally as important as naming the parent clip itself ... even more so now, given the Continuous Clip Recording functionality in the newer camera firmware 2) Ability to import and export logging data ... this would open up a much needed ability to share logging tasks between different installations, log proxies on one machine, import on another. It could also open the possibility of real world proxy editing solutions for FCP users (if the logging file format adopted conformed to an open standard such as XML). 3) Ability to create and edit Clip Lists in the XDCAM Transfer software, and write these back to the XDCAM discs ... this would greatly enhance interoperability between systems including between Mac and PC versions of the PDZ-1 software. 4) Better feature parity between Mac and PC versions of the PDZ software Last edited by Andy Mees; February 24th, 2008 at 07:36 AM. |
I agree with number 3 on the wish list. I was hoping it would show up in this version. However... there is another feature I bugged Sony about that IS in this new release.
If you go to list view mode, you can now COPY that data to the clipboard. That is huge because it opens up the ability to then import that list into EXCEL and add more fields for comments, thumbnails, etc. EXCEL has a very powerful and flexible external data import function. But not just EXCEL... any application that can use the clipboard data will benefit. The other option is to buy a SQL ODBC driver for the Mac and access the file directly. -gb- |
#5 |
I just stumbled on to something that may or may not have been possible in earlier releases.
With a source selected in the left window panel, do a cmd-a to select all. It will select every one of your sources and show them as a master list or master thumbnail view. You could then sort by everything you shot in 24P, or any number of other criteria. I was actually trying to select all clips on one disc in the thumbnail view but because my window focus was in the source panel, I found this little gem. -gb- |
