House Sync on PDW-F70/75 Decks at DVinfo.net
Old February 6th, 2008, 12:04 PM   #1
We've got our equipment on order, but I am now drawing up plans to hook everything up.
We have one of those Horita black burst generators that we used to generate house sync on our SD system. Do the PDW-F70/75 decks use the same sort of black burst signal as reference video? Or is there now some sort of HD flavor of black burst?
Tim Allison is offline   Reply With Quote
Old February 6th, 2008, 05:35 PM   #2
regular house synch is fine.
Mark Silva is offline   Reply With Quote
Old February 7th, 2008, 09:15 AM   #3
Images: 1
I can tell you that the cameras require tri-level sync in order to work properly, not certain about the decks. I suspect they are the same.
-gb-
Old February 7th, 2008, 11:30 AM   #4
The PDW-F** decks only require 'regular' NTSC sync. Tri-level sync is needed for certain decks running 720/24-30-60p, but not for these decks unless tri-level is your house sync.
Keith Rollinson is offline   Reply
