transfer back to Prof.Disk at DVinfo.net
Old November 12th, 2007, 07:29 AM   #1
I am using Vegas 7 & 8 most of the time - so I am not too familiar with other programs that offer transfer via FAM.
I rendered a bunch of short masters and want to write them back to disk.
Is there a way to write several files AT THE SAME TIME back?
Until now I only found a way to write back ONE file at a time.
Any idea?
ULI
Uli Mors is offline   Reply With Quote
Old November 15th, 2007, 04:09 PM   #2
Flip4Mac offers a transfer back to the disc, the PDF is located here:
http://www.flip4mac.com/pdfs/PRO_XDC..._UserGuide.pdf
See the section on transfering media back to
Exporting Media from Final Cut Pro
Flip4Mac XDCAM allows you to export media you’ve rendered as IMX directly out of Final Cut Pro onto an
XDCAM as an MXF file. With Flip4Mac XDCAM installed, a new menu item is added to the Export menu:
• Sony XDCAM (Ethernet)
Regards
Steve
Steve Cahill is offline   Reply With Quote
Old November 16th, 2007, 03:47 AM   #3
Yes. Open the XDCAM disc on the desktop and drag your MXF files to the Clip folder. The camera will refuse other types of files being copied to this folder, but it should work for MXF's as long as they are the same type as the format of the disc.
Simon Wyndham is offline   Reply With Quote
Old November 16th, 2007, 03:58 AM   #4
HI Simon,
never tried this - IŽll have a try later today, that would help much!
ULI
Old November 19th, 2007, 06:20 PM   #5
THAT is EASY...
Thanks for the hint.
Now I can batch render clips from Vegas and simply copy them to Disk for archiving...
ULI
Old November 25th, 2007, 02:33 PM   #6
Will the camera automatically generate the proxy files too - or is that only done when recording?
I guess I shouldn't be so lazy and try it myself... ;)
Paul Gale is offline   Reply With Quote
Old November 25th, 2007, 02:36 PM   #7
Images: 1
Yes it will.
-gb-
Old November 25th, 2007, 03:27 PM   #8
Thanks - I guess the U1 will do the same when the write firmware is out?
Old November 25th, 2007, 03:37 PM   #9
Images: 1
That I don't know. I would presume that to be the case, however. It's kind of an underlying rule of XDCAM that all full res material shall have a proxy file to match.
-gb-
Old November 26th, 2007, 02:51 AM   #10
I guess so. Otherwise you couldnt exchange U1 Masters to other U1 user/studios and use the proxy files...
ULI
Old November 26th, 2007, 11:32 AM   #11
AFAIK When you write back to a U1 the software on the computer will generate the proxy file.
Old November 26th, 2007, 11:35 AM   #12
I guess that's why the proxy files are 'relatively' poor quality for their large size, compared to say an equivalent wmv/mov etc file - it must be all about speed of creation.
Old November 26th, 2007, 02:16 PM   #13
Images: 1
The proxies are 1/4 the resolution of the full resolution material. They have many uses, one of them being smaller size for web transmission.
-gb-
Old December 6th, 2007, 11:50 AM   #14
strange - today I tried that again (select a bunch of HD mxfs, copy to CLIP folder) with some NTSC 60i footage. Didnt work (Alert).
Copying via Vegas works (so the MXFs do correspond the disks settings)
hm......
Old December 7th, 2007, 03:06 AM   #15
Hi,
yesterday I tried to transfer 8 2Gig MXF Files back at once to disk (CLIP Folder) via Desktop - but only got an Alert Message....
Disk was fresh formatted, but it didnt work.
Transfer via Vegas worked fine.
I am investigating if this is due to a very fresh disk (perhaps not "knowing" the video format yet)
uli
