Sony FX9 - Third Party Batteries with D-Tap at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Digital Cinema Camera Systems
Sony F65, PMW-F55 / F5, PMW-F3, NEX-FS700, NEX-FS100 (CineAlta) and PXW-FS7 / FS5 (XDCAM)
Old July 15th, 2021, 07:15 PM   #1
Hey Everyone, looking for a BP-U battery with D-Tap. Tried a battery from Kastar only to have it not recognized by the camera. What are people using on their FX9? Wanting D-Tap to power a monitor mounted on the camera.
www.m3films.com
Jeff Zimmerman is offline   Reply With Quote
Old August 5th, 2021, 10:07 AM   #2
Re: Sony FX9 - Third Party Batteries with D-Tap
Thought I would post that I found a great battery for the FX9 by Hawk Woods. Has two D-taps and comes in 98Wh which should last 2-3 hours depending on use. Ordered and testing one now.
Adorama link: https://www.adorama.com/hwbp98ux.html?kbid=68009
www.m3films.com
Old August 8th, 2021, 09:22 PM   #3
The only non Sony one I'm aware of Jeff is the Swit LB-SU98 Battery (Sony BP-U). IF you can get one! Comes with D Tap and USB ports. Claims the following:
98Wh / 6.8Ah High Capacity
With 14.4V nominal voltage, the LB-SU98 has 98Wh / 6.8Ah capacity, and can run approx. 3 hours on SONY PXW-FX9 camera
Chris Young
https://www.lemac.com.au/Products/Sw...tteryPack.aspx
Old August 9th, 2021, 04:29 PM   #4
Supports LPFM Radio
There's the CORE Nano U-98, a 98wh BPU Style Battery with a P-Tap and USB port... $250US. Available at all the usual places.
No experience with this battery, though I'm thinking of buying a couple for my Canon C70...
https://coreswx.com/shop/nano-u98/
Jim Feeley is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Digital Cinema Camera Systems
