A7rii 4k footage from Japan at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony Alpha Mirrorless and DSLR
Sony Alpha a7s: Full HD Recording in XAVC and 4:2:2 UHD 4K Output via HDMI.
Old October 15th, 2015, 07:00 PM   #1
all handheld using the new Zeiss Batis 25mm and 85mm lenses, still trying to get the best movement using IBIS, some better than others but overall fairly pleased with the results. Some of the ISO was up around 2000, but most was in the lower ranges, 100 - 640 or so.
descantproductions.com cloudgate.tv
Sony and Zeiss, FS700, FS100, A7s, A7rii, RX100MkII
Jem Moore is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony Alpha Mirrorless and DSLR
