Sony 28-135mm f4 lens, Breakthrough Photography, Xume adapters
I put a video together of the Sony 28-135mm f4 lens, Breakthrough Photography NDs and Xume adapters.
Hope this helps someone. |
Re: Sony 28-135mm f4 lens, Breakthrough Photography, Xume adapters
The lenshood is a great solution as an extra protection to keep the filter in place, I have such a xume adapter but never ever will use it again, my expensive nd filter came off and got damaged, the magnet does keep it in place but I accidentally bumped the lens causing the filter to pop off and smash onto teh ground, now I only screw nd filters on. I also had issues getting the xume ring of from the lens, it was so tight I had to use a lot of force to unscrew it.
That's excellent!!! I had to shoot some exteriors of a building in the middle of the day yesterday, as b-roll for an interview i shot indoors, and I was at like f8 and 1/500 shutter to not overexpose. If I wanted any depth of field at f4.0, or wanted motion without that high speed shutter stutter, I would have needed ND's.
So the 82mm filters don't vignette??????? Paul |
Not that i can see.
These are grabs straight from the A7s brought into Avid then exported as a Jpeg. The light is changing so fast here today so there may be some colour temp changes in the images, nothing I can do about this. |
