#31 |
Re: FE SONY 28-135 - question
#32 |
It must be noted that the transition to digital zoom is not clean, there is a pause and should not be used while recording. Another weird thing, on my A7s, if I attempt to change exposure (ISO) settings while the power zoom is in action, the camera locks up, as if it get's a brain seizure. Very annoying when you want to compose and expose your next shot as quickly as possible, and don't want to wait 30 seconds for the zoom to complete.
Paul |
#33 |
Paul,
You must have a light touch. The 28-135 zoom rocker is variable speed. I can zoom all the way from 28 to 135 in about 8 seconds. Same speed the other way. Or are you talking about using the camera to (digital) zoom? Why would you want to use that for Video anyway? |
#34 |
I know Roger, i was being a big sarcastic. I am use to my broadcast 22x lenses that go from 28mm wide to full telephoto in UNDER one second. heck, even my PXW-X180 25x can do that. 8 seconds for a 5x is excrusiatingly slow! The concept of zooming in to focus then pulling back to record is no longer a possibility for me in ENG. It will take me some time to get used to the UP for telephoto and DOWN for wide angle. At least the focus rotates in the correct video direction!
One thing I am finding necessary when using A/F at night, is to leave the manual focus ring set to near infinity, so if the lens looses focus I can pop it back and then forward again, which resets the A/F to begin again at infinity. BTW, here is some night ENG footage on the 28-135 all at f4.0 on my A7s. Paul |
#35 |
Looks good Paul,
What picture profile are you using. |
#36 |
PP4 ITU709, black level at -2 and and auto knee, but otherwise stock. The green light is actually one of those newer white streetlight type lamps that looks green to a Sony camera, much more so than any other camera I have. This was a situation where you would not be able to use a light whatsoever, and the f4.0 was not much of a disability.
The majority of the wobbling and shaky video was the result of me hunting for the controls on the lens, it's very difficult to do anything while rolling, as your supporting hand has to move around to rotate and flip things. I should get a bit better with practice. I found that pressing the EVF against my face helped steady the heavy rig much more than I can get with handholding my PXW-X180. Paul |
