Matching Slog-2 and A6000? at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony Alpha Mirrorless and DSLR
Sony Alpha a7s: Full HD Recording in XAVC and 4:2:2 UHD 4K Output via HDMI.
Old August 20th, 2015, 11:45 AM   #1
I'd like to use an A6000 with a speedbooster as a second camera to my A7S, but I'm in love with shooting SLOG-2. Is there anyway to match the A6000 footage or is it way too laborious?
www.rafael-lopes.com
Rafael Lopes is offline   Reply With Quote
Old October 16th, 2015, 03:55 PM   #2
Re: Matching Slog-2 and A6000?
You have to transform slog2 to REC 709 - so there are at the end not significant differences between the pitures - except greater dynamic range. You can set A6000 very flat too.
I use both cameras togehther - A6000 as a flying camera.
Ivan Mosny is offline   Reply With Quote
Old October 17th, 2015, 09:45 AM   #3
Does the A6000 have anything besides the standard Contrast/Saturation/Sharpness adjustments?
To make my NEX-5R more closely match the A7S I put contrast at -3, saturation at +2, and sharpness at +1. If you want to shoot flat you can also dial back saturation if you're trying to shoot flat.
Matt Sharp is offline   Reply With Quote
Old October 17th, 2015, 12:42 PM   #4
A6000 has much more useable creative styles. Portrait and neutral have great dynamic range.
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony Alpha Mirrorless and DSLR
