Anti-twist plate for Battery Grip at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony Alpha Mirrorless and DSLR
Sony Alpha a7s: Full HD Recording in XAVC and 4:2:2 UHD 4K Output via HDMI.
Old June 18th, 2015, 04:44 AM   #1
Well one solution always seems to create a new problem. I've been using the A7s on a 'shooter' type rig and with an anti-twist plate (actually for the 5D but works with the A7s) the camera has been rock solid.
Now I've bought the battery grip of course the bloody thing has a rounded base rendering my anti-twist plate pretty useless - now every 5 minutes I find myself having to re-tighten the tripod plate screw - why do stills cameras have no anti-rotation pin hole
Any solutions?
Peter Rush is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony Alpha Mirrorless and DSLR
