A7s Battery Grip at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony Alpha Mirrorless and DSLR
Sony Alpha a7s: Full HD Recording in XAVC and 4:2:2 UHD 4K Output via HDMI.
Old June 15th, 2015, 03:04 AM   #1
A7s Battery Grip
The Sony one is a bit pricey - anyone using other makes such as the one below?
Meike MK-AR7 Built-in 2.4g Wireless Control Battery: Amazon.co.uk: Camera & Photo
Pete
Old June 23rd, 2015, 07:31 AM   #2
Re: A7s Battery Grip
I have the Neewer version and it works flawlessly.
However, double nothing is still nothing.
And, I've tried a half dozen aftermarket batteries
all with less or only slightly longer life regardless of mAh rating.
The solution I found for unattended Video of over 3 hours
was a Neewer dummy battery with Small Rig Sony 970 battery plate
and an Odyssey 7Q+ with Indigo dummy battery plugged into a Poweradd power bank.
Roger Martin is offline   Reply With Quote
Old June 23rd, 2015, 08:49 AM   #3
Well I ended up buying it and it seems ok - nice to go twice as long without changing battery :)
Peter Rush is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony Alpha Mirrorless and DSLR
