a7s xavcs premier cs6 at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony Alpha Mirrorless and DSLR
Sony Alpha a7s: Full HD Recording in XAVC and 4:2:2 UHD 4K Output via HDMI.
Old June 4th, 2015, 12:56 PM   #1
Am I missing something? I have a Sony a7s and record using the xavcs codec, import directly into adobe premier cs6 and it edits just fine! Have I been doing something wrong and not realized?
Tom Cambridge is offline   Reply With Quote
Old June 6th, 2015, 07:49 AM   #2
Re: a7s xavcs premier cs6
Where you see a problem?
Ivan Mosny is offline   Reply With Quote
Old June 9th, 2015, 02:16 PM   #3
The problem is I have been reading on the internet that xavcs does not work on premier cs6 and you need the newer creative cloud software to edit xavcs but as mentioned above it works fine for me on s6 thus making me think I'm doing something wrong and I am not actually recording in xavcs!
Old June 10th, 2015, 04:18 AM   #4
Don`t worry. It definitelly works on CS6 very well.
Old June 14th, 2015, 02:53 AM   #5
Works fine on CS5.5 as well
Old July 3rd, 2015, 09:57 PM   #6
Yeah I read it didn't work also. Yet when I bought the Sony AS100V Action Camera that records XAVC-S it worked fine too! :)
David Banner is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony Alpha Mirrorless and DSLR
