Glitch at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony Alpha Mirrorless and DSLR
Sony Alpha a7s: Full HD Recording in XAVC and 4:2:2 UHD 4K Output via HDMI.
Old May 31st, 2015, 09:31 AM   #1
Glitch
Anyone have an idea what this A7s glitch is? It's a fairly new Trancscend card - used a couple of dozen times but never seen this. The rest of the footage so far seems ok
In fact since moving from tape about 4 years ago I've never suffered a glitch - well now I have. I use transcend cards all the time without issue - or is it the camera?
The format is XAVC and the card is a class 10 30MB/s
password: makeup
Old May 31st, 2015, 10:15 AM   #2
Re: Glitch
I have had a similar issue on my ax100 but not as bad as you, have not seen it again and I"m using sandisc cards.
Old May 31st, 2015, 11:28 AM   #3
Re: Glitch
My guess is in camera processing. Not the card. There is so much going on between light striking a sensor and becoming a digital image it blows my mind. The card is just a repository of the processed data. I think that anomaly was created someplace other than the card.
Steve
www.CorporateShow.com
Old May 31st, 2015, 03:50 PM   #4
Re: Glitch
Peter don't go into this to much but the last time i had a Sony i had glitches all over the place like that exactly? It was not the card but the tape deck system in the tape days then it was something else on another hd cam, also maybe look at the the graphics card on your computer it may need a upgrade due to the sony a7s full frame and codec. steve
Old May 31st, 2015, 03:52 PM   #5
Re: Glitch
Peter also i have binned my 30mbs and got all new 95mbs of amazon and they are brill. class 10 32gb 95mb
Old May 31st, 2015, 07:11 PM   #6
Re: Glitch
Hi Pete
Have you attempted to copy the files from card to drive a second time? I have had the odd glitch and found out that is disappeared when I re-copied the file to my drive.
Worth a shot as a lot of the time the glitch is when the computer writes the file to the drive and not when the camera writes to the card. That's why I try to hold off using my current cards until I have checked the footage ..then I can format them!!
Chris
Old June 15th, 2015, 08:24 AM   #7
Re: Glitch
Steve can you send a link - I've just bought 2 SDHC 90MB/s 600x and they won't work - they'll only record AVCHD and the camera says they're not compatible with XAVCS - I've just read the manual and it's right - you can't record XAVCS on SDHC cards - opened em now so can't send them back - bugger!
Pete
Old June 23rd, 2015, 02:50 PM   #8
Re: Glitch
Peter sorry for late reply been away filming in Ibiza, these are the ones i have, but just checked and not sure if they are ok for you. steve
http://www.amazon.co.uk/gp/product/B...ilpage_o05_s00
Steve Bleasdale is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony Alpha Mirrorless and DSLR
