Sony A7s with 3-Axis Stabilizer - video at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony Alpha Mirrorless and DSLR
Sony Alpha a7s: Full HD Recording in XAVC and 4:2:2 UHD 4K Output via HDMI.
Old April 21st, 2015, 01:04 PM   #1
I made a short video with the Sony A7s on the Nebula 4000 3-Axis Stabilizer. Camera was recording in APS-C mode because of the wide lens I used. This is filmed with my custom picture profile.
Here's the video of my quick walk in the park:
Derran Rootring is offline   Reply With Quote
Old April 21st, 2015, 01:36 PM   #2
Re: Sony A7s with 3-Axis Stabilizer - video
Looks fantastic but how long does it take to set up ?
Old April 21st, 2015, 03:50 PM   #3
That is beautiful, well done.
Anthony McErlean is offline   Reply With Quote
Old April 21st, 2015, 06:27 PM   #4
Thank you Anthony!
Setting up takes about half an hour the very first time. Once set up, you can take off the camera and mount it back on the Nebula in just a few seconds. When you need a different camera/lens combination the setup will only take a few minutes.
Old April 22nd, 2015, 03:08 PM   #5
Which lens are you using in the video?
Matt Sharp is offline   Reply With Quote
Old April 22nd, 2015, 05:42 PM   #6
It's the Sony 16mm pancake lens with ultra wide converter (camera was recording in APS-C mode).
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony Alpha Mirrorless and DSLR
