Can someone tell me how to enable the 4k output off an A7s before I go crazy? at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony Alpha Mirrorless and DSLR
Sony Alpha a7s: Full HD Recording in XAVC and 4:2:2 UHD 4K Output via HDMI.
Old February 12th, 2015, 04:12 PM   #1
I cannot get this off Google or the manual.
At least, not without $80 more coffee and facepalming.
How the heck do you enable the 4k HDMI output? Mine is greyed out and despite all the combinations I run through, nothing enables it. The camera was new around Nov 2014.
Old February 12th, 2015, 07:33 PM   #2
Re: Can someone tell me how to enable the 4k output off an A7s before I go crazy?
It may be an EDID issue - have you set the record format on the recorder (I assume it is your new Shogun) first? 4k is new enough you may need to "force" the EDID handshake.
Old February 12th, 2015, 07:49 PM   #3
Starting around 25 minutes on this video:
Old February 27th, 2015, 11:20 PM   #4
Austinite
It just popped up for me. Hmmm...
Phil Goetz is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony Alpha Mirrorless and DSLR
