XLR-K1M Problem on Sony A7s at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony Alpha Mirrorless and DSLR
Sony Alpha a7s: Full HD Recording in XAVC and 4:2:2 UHD 4K Output via HDMI.
Old January 31st, 2015, 07:45 AM   #1
I'm using the Sony XLR-K1M adapter on my A7s, and for the most part it's been great but it's not without its problems. I would like to ascertain if the problems I'm experiencing are down to the device I have or more widespread.
I'm no audio engineer so you'll have to excuse some of my terminology but using certain microphone configurations, I get what I would describe as 'crosstalk' between channels.
Using a radio mic going into input 1 (channel 1) of the K1M, and a hard wired lapel mic with phantom power on input 2 (channel 2), I can hear what sounds like a quiet but over-attenuated signal of input 1 on channel 2. A colleague has suggested input 2 is some how picking up some of the radio mic signal. On channel 1 I do not hear any crosstalk from input 2.
In another situation using two radio mics going into each channel, I have not had any of these crosstalk issues.
If I have no input on input 2 and set input 1 to record to both channel 1 and 2, I do not get crosstalk issues.
If I have no input on input 2 and set input 1 to only record to channel 1, I can hear the crosstalk on channel 2. You can hear an example of what channel 2 sounds like in this case here:
https://www.dropbox.com/s/ol3jsqnhef9rtn9/test.wav?dl=0
Has anyone else experienced this, or know what could be the cause?
Miles Stowey is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony Alpha Mirrorless and DSLR
