Sony a7s 30 min clip limit - Page 2 at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony Alpha Mirrorless and DSLR
Sony Alpha a7s: Full HD Recording in XAVC and 4:2:2 UHD 4K Output via HDMI.
Old September 18th, 2014, 03:18 PM   #16
Re: Sony a7s 30 min clip limit
Okay, important correction. I just did the test again and this time I set the "sleep" mode to 1 minute and didn't touch the camera. Recorded for 5 minutes without the camera going to sleep and without any issues.
I chalk my test last night to A) It was late. B) I was tired.
Seems when it's doing HDMI out it DOESN'T go to sleep and you can record for an unlimited amount of time.
MediaSpigot LLC
http://www.mediaspigot.com
Ryan Douthit is offline   Reply With Quote
Old September 18th, 2014, 03:33 PM   #17
Originally Posted by Ryan Douthit View Post
Doesn't seem to be. It's adjustable, but there aren't any options longer than 30-minutes max.
Really? Can't switch sleep mode off? Hdmi out then stops?
Well, that's ridiculous and makes it a useless camera for me. Was just about to buy one or two, but they have to keep on rolling with Shoguns stand-alone.
Cees van Kempen
www.iwp-wildlife.com
Cees van Kempen is offline   Reply With Quote
Old September 18th, 2014, 03:37 PM   #18
Thank god.
Would be very happy if someone could test if it also doesn't switch off after more than 30 minutes with an hdmi device connected.
Cees van Kempen
Old September 18th, 2014, 06:45 PM   #19
I made a 2.5 hour recording with an Atomos Blade over HDMI and and AC power adapter.
No A7s heat problems and no breaks or pauses.
No internal XAVC-S was rolling, only HDMI output.
The camera "knows" when HDMI is connected and stays awake with no problems.
CT
Cliff Totten is offline   Reply With Quote
Old September 18th, 2014, 07:06 PM   #20
Ah, thank goodness. All is well!
Steve Kimmel is offline   Reply With Quote
Old September 18th, 2014, 08:32 PM   #21
Yup, nothing to worry about with the A7s HDMI. They did not add any sneaky crippling tricks.
It's an honest, non stop output.
The only slightly annoying thing is that if you are recording XAVC-S internally, when it hits its 29 minute limit, it will give an audible "beep" when it stops the recording. This sound will get picked up on your HDMI recorder. The solution is to just not record internally. The HDMI does not studder or glitch or give you any problems.
I hate the micro HDMI port but if you are delicate with it and protect it with a "Lock Port" protector, I think it should last the life of the camera.
Old January 13th, 2015, 10:14 PM   #22
Re: Ryan Douthit's tests "Test was done with the back LCD on simultaneous to the HDMI out."
I am using a sony a7 and attached the Ninja Star as a work around for the 30 min clip limit, but when I turned on the ninja star I lost my LCD monitor image.
Am I missing a crucial setting, or does the video monitor cut out when attached to an hdmi device?
Thank you for your help!
Meredith Sward is offline   Reply With Quote
Old January 13th, 2015, 10:52 PM   #23
I don't have my camera in front of me, but that's a setting in the camera. You can choose to enable or disable the back screen.
MediaSpigot LLC
Old March 14th, 2015, 09:46 PM   #24
Originally Posted by Steve Kimmel View Post
That's too bad as I was hoping to use it as a stand-alone camera that I don't need to monitor over periods for more than 30 minutes.
Mine will be here Monday. I will initially be using a Ninja II external recorder.
The LCD going to sleep is not the issue for me. However,
It will be returned the same day if the A7s cannot go over 30 minutes unattended of HDMI recording.
Roger Martin is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony Alpha Mirrorless and DSLR
