Sony A99 doubt at DVinfo.net
Go Back   DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony Alpha Mirrorless and DSLR
Sony Alpha a7s: Full HD Recording in XAVC and 4:2:2 UHD 4K Output via HDMI.
Old July 13th, 2014, 08:14 AM   #1
Sony A99 doubt
Hi guys,
I've been testing a Sony A99 and I can only use full manual control when I set the focus to manual. Is this correct? I can't use AF while using full manual control??
www.rafael-lopes.com
Rafael Lopes is offline   Reply With Quote
Old August 3rd, 2014, 03:59 PM   #2
Re: Sony A99 doubt
I have an A77, but i think it is the same. AF happens at f3.5.
so AF not usable in manual mode.
but there is a trick to combine manual with AF.
would need to look it up though...
Christophe Gryspeert is offline   Reply
  You are here: DV Info Net > Sony XAVC / XDCAM / NXCAM / AVCHD / HDV / DV Camera Systems > Sony Alpha and NEX Camera Systems > Sony Alpha Mirrorless and DSLR
