#46 |
Re: New Sony A7s to shoot 4K video
Even 204000 iso looks usable with a bit of neatvideo treatment, I guess at that point the camera sees a lot more then what your own eyes can perceive. I want one!
#47 |
It's funny, when I try to capture a dark scene, I try to capture it as my eyes see it. I really don't see the point in making a night scene look like daylight. But then again I've never understood the obsession on having a camera that can do this.
A clean shot whose brightness is indicative of what you see? That I can see (no pun intended). But making daylight from night? Not so much. |
#48 |
I guess I get the "oh wow" on the high ISO but who wants to shoot anything in light that bad. The jello effect is pretty bad.
#49 |
About the RS (is posted this also in EosHD):
I noticed also RS when playing with the camera. The video makes the A7s look unusable. But just for your info, attached to this A7s was a 70-200mm lens and it was fully zoomed in on the video above. So who is doing a pan like this at 200mm? I don't. Yes for sports it is the wrong camera, but for filming under controlled situations to do a real estate video for example, this is the perfect camera. I have no idea how the rs will look at a GH4 at 200mm. Maybe it will not be that extrem but it will be there for sure! On the other side when I compared the noise level between the A7s and the Gh4 there was a difference like night and day between both cameras ;-) |
#50 |
What's potentially really cool for me is with this camera is I can get a usable footage with two of my battery operated k4000s led lights, since I'm a one man show this can really help in certain circumstances. Likewise I could show up at a location with just the camera and the same two led lights and presto, I'm ready to go since I can rely on the camera to get usable footage. No cables, no mass of lighting gear, just two light stands, two k4000 bi-colors and the A7s. I definitely want one, but it all comes down to price. At $3000 I'll probably wait, at $2000 I'll buy, in between I'm not really sure yet.
#51 | |
Wildlife may be another instance. |
#52 | |
At weddings you don't "light" a scene, you take it as it comes, most dslr's that can do 6400 iso have no other option then shoot at f1.4 when it gets too dark, having the luxury to shoot in the ranges of 100 or 200 thousand iso opens up many more possibilities |
#53 |
The ax100 has the same problem, yet I only have seen the issue once where there was faster panning when following a moving train. If you know here the RS can ruin your image you can shoot accordingly and nobody will ever notice. Just don't use it as a sports camera :)
#54 |
OK I get it. I understand event shooters can use the extra stops. I would prefer less RS than night vision.
#55 |
Event shooters will be hampered by the 30 minutes video limit, even outside of the EU.
#56 |
Uh oh. There is a 30 minute limit in the US? Where did you see this?
#57 |
"Event shooters will be hampered by the 30 minutes video limit, even outside of the EU"
Specs on the Sony US website do not mention any recording time limit at all. (check out 1st link in this thread). Cheers, Vaughan |
#58 |
The 30 minute limit is in a NAB video interview with Sony. Same limit in RX10. But some other people got conflicting information. This really needs clearing up from official sources.
#59 |
This new high-sensitivity full-frame camera opens up some interesting possibilities.Take the poor indoor sports photographer (or videographer) who has a full-frame sensor camera and needs to carry a tripod and a $11,500 Canon 400 mm f2.8 lens to be able to shoot at a decent shutter speed. If this camera gives you an additional three full stops of light, he can suddenly switch to a $1400 Canon 400 mm f5.6 lens and still have one additional stop of shutter speed. Perhaps someone will make a few very small light telephoto lenses with a maximum aperture of f 8 at a much lower price. The resolution across the lens field should be excellent at such a small aperture. Such a lens would be great for birds in flight or other outdoor photography as well, and for video you have the additional benefit of much less demanding focus. For situations when you wanted a shallow depth-of-field, a variable Gaussian blur could be added in post. I see a real future for this sensor and others like it.
#60 |
Not so long ago I had read that exmor sensor technology was restricted to small sizes. This is the first camera to utilize it for FF and the benefits are eye popping.
So far the usable iso was 4-5 stops below the highest value. If the same rule applies that means that 13200 iso could be production material which is amazing. The only thing that remains to be seen is the dynamic range. Usually so dimly lit scenes have very high contrast, so in order to shoot with such high iso, you also need all the dynamic range you can get. Definitely will retire a lot of flashguns... |
