#106 | |
Re: New Sony A7s to shoot 4K video
My wife once had one of those very cheap handicams that could do 200x zoom...:)
From what I have seen 80.000 iso seems usable, once above that the noise becomes very noticeable but just the fact that it can is quite amazing. I have seen my ax100 goes to 33db of gain but iit looks like 24db of gain on my cx730, numbers don't always say all about sensitivity it appears as you probably have to take sensorsize into consideration as well. Quote:
#107 |
Agreed. Looking forward to more samples of something besides S-Log. More of what the camera can do without intense color correction and grading.
Dan Carter: HDC-TM700, DMC-GH2 and DMC-GH3, Sony RX100II and RX10, Final Cut Pro X http://www.vimeo.com/user582748 |
#108 |
Do you guys think the A7s could work as a deep dof run&gun type video camera in full auto? So like lock it at F8, put a native aps-c lens on there, set it to full auto and go? Given it's great sensor in low light I figure maybe that means it's auto focus in video could be more accurate than on other camera gear, so I could dual purpose it as a full frame shallow dof bokeh low light monster when needed but also use it for times when I need deep dof full auto good low light video performance. I wonder if this camera could be a master of both (for video, not stills).
#109 |
I too wouldn't buy it based on this video but if you watch it in HD and stop it to gaze at various frames, the details in that low light footage is pretty amazing. To my eye, it looks like it definitely needs some grading but the detail is there. The darker scenes just need to have the shadows brought up and some chroma added back in. In the right hands, the A7S is an amazing camera. The whole "its a poor carpenter who blames his hammer," comes to mind but I believe this camera will prove to be a pretty decent hammer (not literally) for the cost of admission. I know I'm trying to justify buying one.
#110 |
dslr and full auto don't go together, especially not full frame camera's, I highly doubt the autofcus to be very efficient in dark environments. This is not a run and gun camera, focus is always tricky on a full frame camera. If you want deep dof and good auto functionality, sort of a set and forget camera then get a videocamera with a smaller sensor.
#111 |
Noa is right the A7s is not at its best for run n gun auto mode, but you can stop it down pretty far in low light with high iso and still have a clean image, you don't need to film full frame either, it has an aps-c mode too.
This was filmed in asp-c mode with full auto this is not my footage and it definitely has some issues but here's what the shooter said "Our first shoot with the Sony A7S. Shot 1080p60 1/60th shutter with Picture Profile 7 (Slog2), with Color Mode changed to Cinema. Graded in Premiere Pro CC using color curves and saturation, the same setting applied to all clips. The goal was to see how well the A7S handled skintones under very challenging, changing lighting conditions: low light, multicolor spots, etc. NR was only used on the first clip (very very low light). Shot handheld using the Sony SEL18-200mm APS-C lens (FS700 kit lens), AUTO ISO, AWB, AF (center spot focus area), IS, manual zoom, built in mics. With this lens and settings, the A7S makes an excellent low-light live/event camera." |
#112 |
Those subjects he followed are well lit but like Peter asked for "deep dof full auto good low light video performance" is asking a bit too much from any camera, even smaller sensor ones. I at least would never trust a dslr in autofocus or any other tracking mode when the lights are low.
#113 |
I guess I should have elaborated on what I meant by "low light", I meant more indoor type lighting and not a moonlight type situation. In my mind outdoors is good light, indoors is low light, and night shots are no light. My bad, I should have been more clear on that.
That video Ade linked is really interesting and is actually what I had in mind, going with aps-c lens to get slightly deeper dof, then keep the camera stopped down to f8-ish to get dof even deeper and hope the sensor can still scoop up enough light to have af work for video while tracking people. This is more for a backup cam really as I use the AX100 for everything and need a backup in case it happened to break on location. I thought of just getting another AX100 as a backup, but have been contemplating an A7s. My theory was that it could work as a full auto run&gun backup camera with indoor lighting if I used it with an aps-c lens and at f8, but then as a bonus I'd have an amazing full frame camera that I could use at f1.4 if I wanted to for other work. I wasn't sure how well the af would perform on it, but after seeing the above video it makes me think it might just work since my filming and lighting situations aren't as challenging as that fashion show video. Thanks a bunch for that link! |
#114 |
Here is another video by this guy. Good lord! Everything looks bad here. I can barely discern a difference. I think he screwed up on his compression settings or something...... these cameras can't be this bad! If I had a choice though I'd go with the 5D3.
#115 |
I can't wait to get mine with the Atomos Shogun!
#116 |
I don't think so either I mentioned this is my mini review of the A7s which can be seen on my website.
The camera shines on a tripod or monopod but once handheld you have to be careful on how you pan and move with the camera. |
#117 | |
#118 |
Michael,
Why do you say there will be no rolling shutter in 60p? The camera does not have a global shutter so no matter what mode you are shooting in my understanding is that you are going to get that lovely rolling shutter skew if you move the camera very much. Philip Bloom makes it clear in his review of the A7s that is has pretty bad skewing with the rolling shutter and I think he would have mentioned if shooting 60p magically solved that. |
#119 |
The Bloom review was a bit of a shocker. Interesting to note he preferred the APS-C format option with FF lenses connected via the Metabones Speed Booster and that's the way I would use it too.
#120 | |
