PXW-Z90 - Aliasing Issues? - Page 2 at DVinfo.net
Sony 4K Ultra HD Handhelds
Old July 22nd, 2018, 03:26 PM   #16
Re: PXW-Z90 - Aliasing Issues?
Originally Posted by Paul Anderegg View Post
Andy, reset your detail level to what you had it at previously, and change from TYPE 3 to TYPE 1. The TYPE settings are the black and white edge thickness applied to the detail filter. Type 1 has the thinnest edging thickness, and provides a much smoother look. As the number increases, so does the thickness. In the larger Sony cameras, this setting is called WHITE and BLACK LIMIT. You may find that this would reduce the aliasing. I found it reduced my aliasing when shooting 720p.
Paul
Thank you Paul This new setting is helping make it look smoother!
Andy Urtusuastegui is offline   Reply With Quote
Old July 22nd, 2018, 11:27 PM   #17
Yay, glad it helped. :-D
Paul
Paul Anderegg is offline   Reply
