mounting wireless at DVinfo.net
Sony 4K Ultra HD Handhelds
Old March 20th, 2018, 02:16 PM   #1
mounting wireless
how are you mounting your wireless receiver to the camera? looking for a bracket for this, my lectro doesnt have a shoemount on it
Jim Stamos is offline   Reply With Quote
Old March 21st, 2018, 12:45 AM   #2
Re: mounting wireless
So, we might need to know what model of receiver you're trying to mount to what model of camera here.
LR? SR? UCR?
Otherwise we can only really recommend gaff tape, velcro, or zip ties as the only truly universal solution.
Lectrosonics does sell shoe mount / 1/4"-20 threaded brackets application specific for their models.
There are also generic ones (such as bracket1.com) that are a metal back with a wrap around velcro that should fit most 'pack' style receivers.
Kevin Lau is offline   Reply With Quote
Old March 21st, 2018, 01:15 AM   #3
I mount my AVX receiver in the XLR jack :-)
Once I had to run an old Sennheizer thing...i plugged it in the XLR and clipped the wire belt clip to the back of the shotgun cable. :-D
Paul
Old March 21st, 2018, 01:31 AM   #4
Have you had issues trying to power it at the same time (over USB) while the receiver is on? I found I could only get clean audio with the receiver running on its internal battery.
Old March 21st, 2018, 10:52 AM   #5
Mini ball-head cold-shoe mount plus a spring-loaded cellphone tripod mounting bracket. Works like a charm on my Sony receiver on an FS5
http://a.co/2W4GrTK
http://a.co/7TEoR3z
Oren Arieli is offline   Reply With Quote
Old March 21st, 2018, 10:56 AM   #6
i have the lectro ucr 100
Old March 21st, 2018, 11:07 AM   #7
Supports LPFM Radio
So if you're trying to mount the UCR100 on a small camera with a hot shoe, you could try something like:
K-Tek K-SPT Shoe Plate Mount
Just add velcro to your RX and the plate
https://www.bhphotovideo.com/c/produ...2855/KBID/3801
Rycote Wireless Universal Receiver Camera Bracket MkII
A couple velcro straps and a mount that
I've worked with both of those; they're fine. There are other similar options. You can find them through the links above (not endorsing B&H, but an easy way to see what various vendors are offering).
Jim Feeley is offline   Reply With Quote
Old March 21st, 2018, 11:34 AM   #8
I got this https://www.bhphotovideo.com/c/produ...2855/KBID/3801
its great!
Randy Johnson is offline   Reply With Quote
Old March 21st, 2018, 11:37 AM   #9
oh it may not work with the 80s and 90s sorry
Old March 21st, 2018, 12:51 PM   #10
I tested the AVX on my old X180 that had a full size always powered USB-A port, and never heard any interference...the red charge light stayed on confirming it was charging while in use.
Paul
Old April 30th, 2018, 05:22 PM   #11
Does that go high enough to fit my lectrosonics in it
And is it staying pretty solid of would I need to Velcro
