Working with HLG footage - Page 7 at DVinfo.net
Sony 4K Ultra HD Handhelds
Old May 22nd, 2018, 07:56 PM   #91
Re: Working with HLG footage
Great news Paul! Thanks for posting the clip, looks excellent.
Old May 22nd, 2018, 09:06 PM   #92
THANK YOU TOM...looks like you posted the "secret sauce" that makes it possible to work in Sony HLG...at least in Resolve. Seems FCPX is totally incapable of properly dealing with HLG at this time. Not surprising there, they are always way behind.
Paul
Old September 14th, 2018, 01:22 AM   #93
Using a Sony PXW-Z90, I set PP1 as SDR REC709 manual knee, and PP2 as HDR HLG/709 auto knee (auto knee required for HLG). I then turned gain to max 33db, started pointing at things that would blow out and clip the highlights, and toggled between PP1 and PP2. I laid the clip on a standard SDR REC709 timeline, and exported without any grading or color space changes, as it was set to 709 instead of BT2020 under HLG color space selector. As you can see, the HLG1 (Sony 87%) PP just sees things that the REC709 doesn't. Exposure was locked down, so no exposure changes were happening when I toggled the PP's, you are seeing the HLG gamma doing some sort of magic...W.O.W.
Old December 9th, 2019, 10:53 PM   #94
Hi Paul,
I know this is an old thread however, did you find any advantage using HLG on Z90 vs Cine 4 or Cine 2 for your style of work.
I've just started shooting HLG3 on my Sony A7III with excellent results and I also use my Z90 in Cine 4 with Doughs profile, I know these are completely different cameras, so was wondering about your results with the Z90.
Cheers mate
Old December 9th, 2019, 11:14 PM   #95
Not playing around with HLG any longer. The black level on the Z90 in HLG ios too high, and I am not motivated to figure out how to set it properly. I did slightly play around with creating an HLG calibration for my Sony HDR TV with a meter, but the lack of real time HDR/HLG output without spending $500 makes it a real PITA to do even simple grading right.
Anything that I shoot in HLG to output as REC709 always looks pretty bad, specifically because the black levels are all wrong, too high, looks bad. The monitor on my Macbook has such a high black level and bad contrast it's not really possible to grade blacks or shadows on it.
Paul
Old December 10th, 2019, 01:06 AM   #96
Thanks for that info mate, this is what I also found however I needed a second opinion.
Old December 10th, 2019, 11:12 AM   #97
Vortex Media
HLG is designed to be used ONLY for "live" output and broadcasting with 10-bit cameras. It is not intended for processing in post and it is not intended for 8-bit video.
Old December 10th, 2019, 11:25 AM   #98
Originally Posted by Doug Jensen View Post
HLG is designed to be used ONLY for "live" output and broadcasting with 10-bit cameras. It is not intended for processing in post.....
That's just sheer nonsense.
Cary Knoop is offline   Reply With Quote
Old December 10th, 2019, 11:43 AM   #99
Vortex Media
It's right in Sony's own documentation. Look it up.
Old December 10th, 2019, 12:08 PM   #100
I have to say that using shooting HLG on my Sony A7III and delivering this as rec709 via FCPX has resulted in the best looking footage I've got outa that camera to date with the least amount of post grading work.
Old December 10th, 2019, 01:53 PM   #101
Well if Sony says it it must be true........
I have worked on countless HLG videos in post.
I must not know what I am doing! :)
Old December 10th, 2019, 03:36 PM   #102
Vortex Media
S-LOG = best for a post processing workflow.
HLG = for live broadcasting and monitoring in a 10-bit environment.
Simple as that.
Just because you can pound a nail with a screwdriver doesn't mean that the hammer wouldn't have been the better choice.
Old December 10th, 2019, 03:56 PM   #103
On my Z90 the HLG results are not great however for the A73 the results are excellent.
My work flow
Shoot HLG3 BT2020 PP10 on the Sony A73
FCPX
Rec 709 project
Import footage
Color Space Overide Rec.2020 per clip
Results look great, colours look natural.
I might have this incorrect however as I said, great results
Old December 10th, 2019, 04:19 PM   #104
Vortex Media
I'm not familiar with the A73, does it have an S-LOG mode for comparison to the HLG mode that you say you like?
Old December 10th, 2019, 04:38 PM   #105
Yep, the A73 has Log profiles which I have found to more of a hassle, I normally use Cine 2 or Cine 4, however lately HLG3 has been my goto profile.
I wish there was more info on HLG and FCPX workflow as there's two two distinctive Color Space Override settings: Rec. 709 & Rec 2020
They both look great with Rec. 709 being less saturated
Simon Denny is offline   Reply
