Using an external monitor w/X70 at DVinfo.net
Sony 4K Ultra HD Handhelds
Old July 15th, 2016, 10:36 AM   #1
I think I must be senile. I have tried all kinds of settings but I can't seem to get an HDMI signal to feed my new monitor.
Which of you Brainiacs will win the cigar?
Dan Gunn is offline   Reply With Quote
Old July 15th, 2016, 11:26 AM   #2
Re: Using an external monitor w/X70
Hi Dan,
Not an X70 owner, but borrow my buddy's X70 frequently ;-)
From the manual:
In Menu - use EXEC button to select (REC/OUT SET) > [OUTPUT SELECT] > the jack that you want to use for output.
Pg. 74 of pdf - https://pro.sony.com/bbsc/assetDownloadController/PXW-X70-Operating-Guide-(45442421M).pdf?path=Asset%20Hierarchy$Professional$SEL-yf-generic-153708$SEL-yf-generic-153753PXW-X70%20Operating%20Guide%20(45442421M).pdf&id=StepID$PXW-X70%20Operating%20Guide%20(45442421M)$original&dimension=original
If memory is correct (without looking it up again), if in 4K record mode, you cannot output live video when recording. Must be in HD mode to get HDMI output. I've used Atomos Assassin and Ninja 2 units with the X70 to record 1080i output via HDMI and worked great for both.
Jeff Pulera
Safe Harbor Computers
Old July 15th, 2016, 12:28 PM   #3
Still no luck. I hope you are wrong about outputting in HD while recording in 4K!
Old July 15th, 2016, 12:32 PM   #4
Is that what you're trying to do, output while recording 4K?
The Ver. 3.00 firmware update recently came out which may fix this issue, as it says "5. External output and the face detection function is now supported when recording in XAVC QFHD."
Have not yet tried this myself. But I'm sure that without the update, you can not output video when in 4K mode, at least not while also recording in camera.
Update thread here - http://www.dvinfo.net/forum/sony-pxw...te-out-v3.html
Jeff Pulera
Old September 14th, 2016, 11:09 PM   #5
Reviving this old thread.
Can anyone confirm whether, with the latest firmware, it is now possible to monitor externally while recording in 4K? Thx.
Old September 18th, 2016, 06:53 PM   #6
Every time I hit the record button, my external monitor goes black. I have the latest firmware, 3.0.
Michael Sims is offline   Reply With Quote
Old September 18th, 2016, 11:25 PM   #7
You cannot get LCD/EVF and video output at the same time in 4K while the camera is actively recording in 4K mode.
Paul
Paul Anderegg is offline   Reply
