Now available: System Software Update V3.00 at DVinfo.net
Sony 4K Ultra HD Handhelds
Old June 16th, 2016, 09:21 AM   #1
A few days early...
Software: PXW-X70 : System Software Update V3.00 (Win + Mac) : Software/Drivers : Canada : Sony Professional
Ervin Farkas
www.AtlantaLegalVideo.com
Old June 16th, 2016, 09:55 AM   #2
Re: Now available: System Software Update V3.00
Ervin, have you applied this yet? Did you use the CA installer you linked to? There's been an issue with the US installer.
Edit: I can report that the US updater, despite being in a folder named FS7 rather than X70 (!) works just fine. The instructions specify using the Sony Multi to USB cable that came with the camera, although some have found that generic cables work, but not always. I couldn't find mine but successfully used the cable that came with my Sony RX10 (mk I).
Also remember to save your Camera Profile before doing this if you have anything at all that you've customized - PPs, Buttons, etc. - so you can restore it after.
David Dixon is offline   Reply With Quote
Old June 16th, 2016, 10:06 AM   #3
A warning has been posted that there may be a potential problem!
Dan Gunn is offline   Reply With Quote
Old June 16th, 2016, 10:07 AM   #4
No, I have not applied the update, and probably won't do it until I get confirmation that it works fine... I'll let others be the Guinea pigs...
Ervin Farkas
Old June 16th, 2016, 05:30 PM   #5
Facebook forum are starting to speak about bricked cameras.
Donald McPherson is offline   Reply With Quote
Old June 16th, 2016, 08:10 PM   #6
Just used the UK file on a US purchased X70. Update went perfect. All is good.
Except,...I forgot to save my camera settings before the update,...again! I did the same dumb thing on the last FS5 update, lol,....so I had to re enter my settings again.
I guess I was too excited to get it loaded that I forgot to backup settings.
CT
Cliff Totten is offline   Reply
