X70 - Live stream to PC at DVinfo.net
Sony 4K Ultra HD Handhelds
Old May 27th, 2016, 06:40 AM   #1
Hi - I have a job tomorrow, I was wondering if it is an easy job to live stream and record the stream on my PC. What is the best way to do it?
Ian Whelan is offline   Reply With Quote
Old May 27th, 2016, 09:53 AM   #2
Re: X70 - Live stream to PC
Hi Ian,
Not clear on the question - do you want to live stream to the internet, or just "stream" from camera over to the PC? If the latter, to what end? Please provide details on intended workflow/desired end results.
Jeff Pulera
Safe Harbor Computers
Old May 27th, 2016, 10:44 AM   #3
Probably this is the best setup streaming to VLC player.
Donald McPherson is offline   Reply With Quote
Old May 27th, 2016, 02:31 PM   #4
I'm shooting teacher training videos tomorrow - each session is 10 minutes long. The client wants me to be able to copy the 10 minute video to USB stick directly following the session to hand to the trainer. I'm thinking the best way to do this might be to stream it and record it directly to the stick.
Old May 28th, 2016, 02:44 AM   #5
No transfer needed. Record to both sd's simultaneously and pop the card in here.
Integral USB Card Reader Adapter SD SDHC SDXC Microsd Single Slot Memory Stick | eBay
Old May 28th, 2016, 08:53 AM   #6
Hi Donald
Thanks for that - that's what I did but I wanted to hand over as MP4 - just gave them AVCHD instead!
Thanks for the help,
Ian
Old May 28th, 2016, 01:11 PM   #7
Alternately, setting proxy will record little mp4 files :-)
Old May 29th, 2016, 04:54 AM   #8
Paul - THAT is a much simpler method and works perfectly! Will use this on the next four upcoming ones. SOOOOO easy!
