X70 Firmware- ETA?? - Page 3 at DVinfo.net
Sony 4K Ultra HD Handhelds
Old June 16th, 2016, 05:30 PM   #31
Re: X70 Firmware- ETA??
Paul - could you point me to the original settings?
Barry J. Weckesser is offline   Reply With Quote
Old June 16th, 2016, 08:59 PM   #32
Originally Posted by Stephen Robinson View Post
Just curious if anyone knows what this means: "HDMI/SDI/composite output selection during QFHD recording."
Right now, I believe the X70 will output to a monitor/recorder during both standby and record while in 1080, but only in standby while in QFHD. That basically negates any benefit of using an external monitor while recording in QFHD. I'm hoping this firmware update will fix this issue. I've been looking into the Blackmagic Video Assist to be used as a field monitor but to also have a second option for recording if I desired. Anyone have any insight on this issue?
Just an FYI, I have completed the V3.0 upgrade. You can indeed output the 4K signal, but it will only output to either your LCD screen or the external monitor. Not to both at the same time. Not huge deal but it would be nice if it would output to both like it does for 1080.
Stephen Robinson is offline   Reply With Quote
Old June 16th, 2016, 11:12 PM   #33
X70 PP's are compatible with the Z150.
http://www.dvinfo.net/forum/sony-pxw...ml#post1871731
Old June 17th, 2016, 05:27 AM   #34
Paul - Just to make sure I have this right - the settings you are currently recommending are found in post #7 on this thread: http://www.dvinfo.net/forum/sony-pxw...-settings.html. - except that the Color Phase is at -2 instead of 0 - is that correct?
