Slow Motion question at DVinfo.net
Sony 4K Ultra HD Handhelds
Old February 16th, 2016, 11:20 PM   #1
Hi all,
The X70 can shoot 1080 50p @ 50fps in S@Q mode (XAVC L 50mbps)
If I put the clip in a 25p timeline, how the clip works?
Will it be 100fps smooth slow motion without judder?
Rajiv
Rajiv Attingal is offline   Reply With Quote
Old February 17th, 2016, 01:22 AM   #2
Re: Slow Motion question
This is for FCPX, I would assume AVID & Premiere are the same, but don't know for sure...........
The fastest frame rate the PAL X70 can shoot is 50fps - it will never be 100fps. Dependant on your situation, I would suggest not to bother with the S&Q modes & just shoot at 50fps all the time.
If you put the footage into a 25p timeline, it will play at normal speed, however you can slow it down in the timeline to 50% and it will still appear to be smooth - any slower than 50% & you will begin to see juddering.
If you really want the absolute slowest slow-mo possible out of the X70 without judder, you could set the camera to film in NTSC 60p & then drop it onto a 24p timeline - that will give you a smooth 40% slow-mo.
Hope that helps!!
Paul Hardy is offline   Reply
