X70 resets parameters on battery exchange at DVinfo.net
Sony 4K Ultra HD Handhelds
Old August 4th, 2015, 04:42 PM   #1
happened more then twice to me:
when the battery is empty so the camera turns off it forgets WB and REC SET parameters,
so I had to reconfigure after the battery replaced. happened both on genuine and aftermarket batteries.
annoying when in a rush.
Yuri Gershberg is offline   Reply With Quote
Old August 6th, 2015, 02:11 AM   #2
Re: X70 resets parameters on battery exchange
How quickly after the camera shut down did you change the battery? Do you get the same problem if you swap batteries before the first one is fully discharged?
Steam Age Pictures - videos in aid of railway preservation societies.
Mark Fry is offline   Reply With Quote
Old August 6th, 2015, 02:27 PM   #3
last time it was a minute or so between the camera shut down
and the battery change since the spare battery was in another room.
taking out a charged battery when the camera is on doesn't led to reset.
AFAIR there always was a "low battery" warning before the settings reset.
Old August 9th, 2015, 12:53 AM   #4
I was filming some wedding speeches yesterday & I had to change one of my batteries before the end, My camera's WB, Iris, SS & Gain all reset to auto & the manual WB lost it's previous value when the new battery was inserted.
Unfortunately I think it's just a camera 'feature'
Paul Hardy is offline   Reply With Quote
Old August 9th, 2015, 04:05 AM   #5
Now in holiday so my user manual is out of reach
AFAIR mostra of the user settings can be sent to the SD (to be shared with other camera): am I wrong?
If it is true, one can memorise its own settings and recall after unexpected reset.
Plese correct me if I am wrong
Sauro Scroglieri is offline   Reply With Quote
Old August 9th, 2015, 01:19 PM   #6
Paul, this is exctly the case.
if this ia a 'feature' why I'm not able to reproduce it twice in a row?
Sauro, you are right about saving settings to the memory card,
but in most cases the camera is not resetting, so this yet to become a habit.
