Lens Hood for X70 at DVinfo.net
Sony 4K Ultra HD Handhelds
Old July 16th, 2015, 11:57 AM   #1
Lens Hood for X70
Has anybody come across a replacement lens hood for the X70 that has a built in shutter/cover - I really miss the hoods from my old NX70's - I wonder if any hoods from other Sony cameras would fit & have the correct mounting grooves?????
Paul Hardy is offline   Reply With Quote
Old July 16th, 2015, 12:01 PM   #2
Re: Lens Hood for X70
This would be such a nice feature. Would be a great aftermarket product eh?
Dave Contreras is offline   Reply With Quote
Old July 16th, 2015, 03:01 PM   #3
I was literally searching for an aftermarket hood today. I would love to have one similar to what they have on the Canon XA20.
Stephen Robinson is offline   Reply With Quote
Old July 16th, 2015, 08:41 PM   #4
I find it ironic that the X70 uses the same lens hood as the AX100...
Why? Because the hood has the aspect ratio for "photographs" on the AX100. (Because the AX100 shoots photos) But the X70 had it's photo ability removed and "should" only have a 16x9 aspect ratio hood for video.
However, Sony decided use the AX100 hood on the X70 anyway. An NXCAM NX70 style hood would have been ideal.
Cliff Totten is offline   Reply With Quote
Old July 17th, 2015, 04:39 AM   #5
That's like the broadcast B4 lenses from Canon and Fujinon. Fujinon sticks with 4:3 lens hoods, Canon 16:9.
Paul
Old July 17th, 2015, 07:52 AM   #6
It would be great to have a built in lens shutter - I'm really surprised that Sony went Forward to the Past with this feature.
I'd happily pay for a solution.
Peter Wright is offline   Reply With Quote
Old July 18th, 2015, 09:31 AM   #7
Count me in. I would happily pay for a solution. I had that feature on my Z1.
Marc Salvatore is offline   Reply With Quote
Old July 19th, 2015, 10:06 PM   #8
If you use a lens hood then you don't need a lens cap. I find most lens caps now for DSLR's causes more damage than not having one.
Stephen Watts is offline   Reply With Quote
Old July 25th, 2015, 04:04 AM   #9
I have a UV Filter attached permanently on my X70s lens. So I do not use the lens cap during days of much filming.
Roland Achini is offline   Reply With Quote
Old July 25th, 2015, 04:13 AM   #10
To be fair, I do the same - the lens caps are never used & i rely solely on UV filters for protection. And now I come to think about it, I used to get really annoyed with the NX70 flip up lens shutters in the rain, as the 'flipping up' would catapult water droplets onto the lens - very annoying!
Old July 25th, 2015, 05:51 AM   #11
I use a B+W clear filter also permanently attached.
Ricky Sharp is offline   Reply With Quote
Old July 26th, 2015, 07:52 AM   #12
You could always try one of the 'Hoocap' range that has a built in lens cap in the hood. I think you would need a 62mm to whatever step-up ring.
Hoocap
Chris Young
CYV Productions
Sydney
Old July 27th, 2015, 05:28 AM   #13
I have a B+W UV clear filter as well which is attached 100% of the time. It not only protects the lens, it also helps keep the dust and elemrents from entering your permanent lens as well. If I come across a lens hood such as the one you're looking for, I'll let you know. Ray
Ray Paula is offline   Reply
