AX100 Firmware 3.0 is out today!! - Page 2 at DVinfo.net
Sony 4K Ultra HD Handhelds
Old March 13th, 2015, 12:56 PM   #16
Re: AX100 Firmware 3.0 is out today!!
Originally Posted by David Arendt View Post
Is the HDMI port still only enabled during recording of 1080i/p or is it now also enabled while recording 4K ?
Where do I find that info back in the menu?
Old March 13th, 2015, 01:05 PM   #17
In fact this info cannot be found in the menu. The only way to determine this is to connect the camcorder to a televsion and see if there is still an image displayed on it while recording.
David Arendt is offline   Reply With Quote
Old March 13th, 2015, 01:11 PM   #18
Ok, so it's not the "hdmi resolution" in the menu, that one does display from 720p to 2160p as selection? Not sure if I can find my hdmi cable but if I do I"ll try
Old March 13th, 2015, 01:12 PM   #19
Anyone know how to get rid of the Zoom buttons on the screen that now appear after the update?
They are distracting and I can't find a setting to turn them off.
Old March 13th, 2015, 01:14 PM   #20
No, the menu entries are always available. Only a black image is outputted via hdmi during recording 4k on older firmwares.
Old March 13th, 2015, 01:20 PM   #21
menu, camera/mic, camera data display -> set to "on"
Old March 13th, 2015, 01:24 PM   #22
Just connected the camera to my tv with a hdmi cable and got an image in standby mode, as soon as I pressed record my tv turned black.
Old March 13th, 2015, 01:25 PM   #23
oh wait, my camera is set to 4k and the tv is 1080p, I take it I should set the camera to 1080p first?
Old March 13th, 2015, 01:26 PM   #24
Noa, that setting is on by default. These zoom buttons are driving me crazy. The come on over top of the screen and I can tap the screen to get rid of it. but then they come right back.
Old March 13th, 2015, 01:27 PM   #25
Just set the camera to 1080p and connected back to the tv, now I continued having a preview on my tv when the camera was recording...
Old March 13th, 2015, 01:29 PM   #26
have you configured your buttons true camera/mic and then mybutton?
Old March 13th, 2015, 01:30 PM   #27
Sorry, wrong setting! try setup, display setting and set this to on
Old March 13th, 2015, 01:36 PM   #28
As you are from Belgium, I suppose you installed the update on the pal model right ? So is it also perfoming correctly on the PAL model and offering 25/50fps ?
Old March 13th, 2015, 01:50 PM   #29
Noa, thanks much! That was it!
Old March 13th, 2015, 01:53 PM   #30
Yes, it's a pal model and when viewing the menu I get 25p and 50p options in xavc s hd and 25p in 4K
Noa Put is offline   Reply
