Sony XLR-K1/K2 or Zoom H5 for Sony AX33/AX100 at DVinfo.net
Sony 4K Ultra HD Handhelds
Old February 26th, 2015, 07:29 AM   #1
I'd like to buy either a Sony AX33 or AX100 in a couple of weeks. Since they come without an XLR audio module, I'd like to buy a Sony XLR-K1/K2 module or a Zoom H5 external recorder with a shotgun capsule.
The Sony XLR comes with the Sony ECM-XM1 Shotgun Microphone the
The H5 has two powered XLR inputs, and it is a bit less ($500 H5 + SGH-6 shotgun mic) expensive than the Sony XLR modules ($600 - 800). Is there any advantage of the Sony XLR modules over the Zoom H5?
Thank You so much for the help,
Miki
Miklos Nemeth is offline   Reply With Quote
Old February 28th, 2015, 06:41 AM   #2
Go Cycle
Re: Sony XLR-K1/K2 or Zoom H5 for Sony AX33/AX100
I own the K2. I use it on my XA-100 and will do so with my ordered AX-33. Works very well. I use the Rode NTG-1 instead of the Sony shotgun. The unit does tend to use a little more draw on the battery but I also own the NTG-2 with its own battery, so that should help. I do miss the handle as found on the X70.
Lou Bruno
Lou Bruno is offline   Reply
