Strange Catalyst Browse levels issue - Page 2 at DVinfo.net
Sony 4K Ultra HD Handhelds
Old April 28th, 2015, 06:59 PM   #16
Re: Strange Catalyst Browse levels issue
The case I opened with them previously, the one in the post up above, was closed. I cannot even access it myself, says it was resolved. :-\
If you have a few minutes to kill, you can select each clip at a time and do the transcode thing. the newest CB version will keep the transcode settings from the previous clip, and the % transcoding will refresh for each clip as you get them going. If I remember correctly in previous CB versions, you had to reselect all the options for each clip, and the % remaining gave no indication of which clip was transcoding, and sometimes locked up.
Paul
Old April 28th, 2015, 07:26 PM   #17
I'm currently using the Catalyst Prepare trial which does no suffer from black level issues when batch converting but once that runs out...
Marc Salvatore is offline   Reply
