X70 FW Update - Page 2 at DVinfo.net
Sony 4K Ultra HD Handhelds
Old November 25th, 2014, 04:58 AM   #16
Re: X70 FW Update
Never had a problem with a Sony FW update... smooth and easy every time... Alphas, Cybershots, Handycams...never a problem if I followed the directions , which sometimes have some quirky steps. I find I leave the directions up after downloading the updates so I can go down the list of steps, and I'm a "who needs stinkin' directions" kinda guy!
Maybe a bad cable or connection? I seem to recall Sony strongly suggested using the USB cable included with the camera, and I know I've got so many USB cables running around I don't know what came with what! And there are USB cables that will "fit" at the ends, but are wired differently...
Just a thought, could be completely wrong, but thought I'd mention it.
Old November 25th, 2014, 06:30 AM   #17
Re: X70 FW Update
Another other need is to connect to mains power for upgrading most of the Sony camcorders and they can tell whether power is mains or battery. At least my NX5U and FDR-AX1need to be on mains powerto updte nd they can tell if it is not.
Ron Evans
Old November 25th, 2014, 07:54 AM   #18
Re: X70 FW Update
Originally Posted by Mike Griffiths View Post
Does anyone have an idea what I should do now?
I had a similar experience on one Windoze box but it had a utility called 'USB Safely Remove' in place of the normal Windows safely remove icon. No way would this PC upgrade the X70. Moved to a another Win 7 box that was running the normal Win USB safely remove icon and hey presto it upgraded without an issue. Go figure!
Chris Young
CYV Productions
Sydney
Old November 26th, 2014, 12:00 AM   #19
Re: X70 FW Update
Thanks, I made sure I used the cable supplied with the camera. Have downloaded 4 versions including one from Singapore ( i live inThailand). not sure what Paul meant when he said ' make sure the version is for your region'
Mike
Mike Griffiths is offline   Reply With Quote
Old November 26th, 2014, 12:19 AM   #20
Re: X70 FW Update
Ron Evans
Tried that too, still no luck I'm on an iMac, I'll try on my wife's Win7 to see if that works
Mike
Old November 26th, 2014, 01:58 AM   #21
Re: X70 FW Update
Chris Young
CYV Productions
Sydney
Wow! plugged in my wife's sony Vaio win 7 and bingo first time!!! There seems to be a problem with the Mac version, don't know if anyone else had the same problem. I confirm using cables other than the supplied Sony one is not a good idea!
Mike
Old November 26th, 2014, 06:44 AM   #22
Re: X70 FW Update
Glad you got it sorted Mike.
Chris Young
CYV Productions
Sydney
Old November 27th, 2014, 01:51 PM   #23
Re: X70 FW Update
Just purchased the PXW-X70........How do you do the update? Anyone have instructions. Thanks, Ray
Ray Paula is offline   Reply With Quote
Old November 27th, 2014, 03:38 PM   #24
Re: X70 FW Update
It's all in the download.
https://www.servicesplus.sel.sony.co...eDownload.aspx
Old November 27th, 2014, 05:24 PM   #25
Re: X70 FW Update
Awesome....... Thanks for the links! Exactly what I needed.....Thanks again, Ray
