Sony PXW-X70 announced: Pro XDCAM version of AX100 - Page 34 at DVinfo.net
Sony 4K Ultra HD Handhelds
Old December 10th, 2014, 06:38 AM   #496
Re: Sony PXW-X70 announced: Pro XDCAM version of AX100
Good one Terence!
But I must admit to being somewhat confused by the statement that you say there is NO front filter thread? Are you sure? Have a look at the pic of the one I have, excuse the shaky phone pic, but you can clearly see the front filter thread and it takes an 82mm screw in. Unless JVC / Fujinon changed the spec at some time? How odd?
Notwithstanding that I think you will get good mileage out of it. Rummage around old photo shops and I'm sure you will find a rear 62mm cap. I have to do this myself. Any decent broadcast dealer is likely to be able to help you out with an 82mm front cap new or used. New you would pay the same for a cap as you did for the lens! Look for an 82mm peanut butter lid :)
Chris Young
CYV Productions
Sydney
Sony PXW-X70 announced: Pro XDCAM version of AX100-wcv-82sc-filter-thread.jpg
Old December 10th, 2014, 10:41 AM   #497
You are right, Chris - it *does* have filter thread. This is a classic case of seeing what you believe to be true. I had previously checked the specs on an obsolete B&H ad that said "Filter size: None". When it arrived I never looked or noticed (not with these old peepers anyway). Great - I'll probably slap on a UV filter for protection - until I find a suitable lid!
Terence Morris is offline   Reply With Quote
Old December 10th, 2014, 05:51 PM   #498
UGH, Adorama did not have two Fujinon converters, just the on that Terence bought! they've cancelled my order
Mike
Mike Griffiths is offline   Reply With Quote
Old December 10th, 2014, 06:09 PM   #499
Aint the EXII pretty on my old CX900? :-)
Sony PXW-X70 announced: Pro XDCAM version of AX100-ex2.jpg
Old December 10th, 2014, 07:21 PM   #500
Very nice, Paul. What's the external monitor you're using?
-Terence
Old December 10th, 2014, 07:54 PM   #501
That is a cheap LED with CTO.
Paul
Old December 10th, 2014, 08:19 PM   #502
Of course...
Old December 10th, 2014, 08:46 PM   #503
Terence what are the front filter thread size?
Paul
Old December 10th, 2014, 09:23 PM   #504
It is 82mm at the front as well as at the back, as the sides of the lens appear parallel. But I double checked with my callipers just to make sure. I think I'll get one of those Bower polarizing filters you had in your video.
-Terence
Old December 11th, 2014, 12:18 PM   #505
Happy to say my 10 year-old Manfrotto LANC remote control pan bar is now working flawlessly with the PXW-X70. I just received a Sony Multi Adapter Cable (SOVMCAVM1) and Manfrotto Adapter Cable LANC/AV-R Sony (MA522AV) from B&H. Much easier to run than using the remote control in your left hand and a standard pan arm in your right. These two cables are needed to make it work. The order arrived in Canada two days after I placed it - shipped at Ground price. Great service from B&H!
Gerry Fraiberg is offline   Reply With Quote
Old December 12th, 2014, 09:07 PM   #506
Does anyone know if the X70 can be jam sync'd to something like a Sound Devices 702T so that it can use free run timecode untethered? I think it would need to have an onboard time code clock.
-Terence
Old December 18th, 2014, 07:52 PM   #507
Good news - Catalyst Browse has been updated to 1.1.0.86, and now includes batch Transcoding of multiple files...
This is not on Sony's web site yet and you can only find it through the app. It's a bit hidden - open Catalyst, at the very top right click Options, then in the box that comes up click About, then in the next box click Check for Updates. Once it finds it you can download, install, and relaunch. The new version is 1.1.0.86 and does indeed give access to the Transcode option even when multiple files are selected. In my haste I did not read the entire list of features/fixes.
Very glad to see this!
David Dixon is offline   Reply With Quote
Old December 18th, 2014, 08:39 PM   #508
thanks David,
Just to say I opened Browse and up came a prompt saying new version available
Mike
Old December 18th, 2014, 08:48 PM   #509
Originally Posted by Mike Griffiths View Post
thanks David,
Same here. I like the fact that it has now caught up with the past and will link files that are part of a single AVCHD clip !!!!!
Ron Evans
Old December 19th, 2014, 05:17 AM   #510
NOT A SOLUTION.
The new version, which have just wasted an hour getting around, will only transcode multiclip mode to AVCHD. It WILL NOT transcode to ProRes, or XAVC on my Mac, but it will transcode to DPX, which will not work in FCP X. So I shot 30 clips on a story, and then another half hour transcoding to DPX to figure that out, now have to ingest via SDI.
What is the point of transcoding to a format you can shoot in camera if it takes 3 minutes per minute of footage to transcode? Pointless.
Paul
Paul Anderegg is offline   Reply
