#301 |
Re: Sony PXW-X70 announced: Pro XDCAM version of AX100
Stephen, I think this is quite excellent. I like the angles and the color out of the camera looks very nice. What color profile where you using? Also, what frame rate?
Thanks. |
#302 |
I like it too. After the sort of mixed reviews so far of this camera, it's nice to see that it is sharper than my current camera - a big factor for me.
How did you edit the piece - at first I thought 1080p60 in a 24p timeline, but it looks slowed down more than that. |
#303 | |
It is shot at 60fps, played back at 24. I did slow down a a couple of the shots a little more in post. As well as speeding up the first shot back to normal speed. It was all shot using the S&Q motion feature. |
#304 | |
#305 |
Stephen,
Which codec did you shoot this in: XAVC or AVCHD?? Also, I'm curious what editing software you are using.
Bob |
#306 |
#307 |
This X70 post could be useful to some of you.
http://www.dvinfo.net/forum/sony-xav...ml#post1864117 Paul |
#308 | |
Also, within PPro CC, exactly what sequence preset are you using for the XAVC timeline? I'm finding that I can work with the XAVC footage in PPro CC 2014, but everything seems a bit haphazard & off the cuff. It's like Sony doesn't really have the infrastructure in place yet for this codec.
Bob |
#309 |
Robert,
When using Adobe Premiere Pro CC you can just copy the MXF files from the SDXC card directly to your HDD using a cardreader and import these in Adobe without any problems. Gabor |
#310 | |
I'm just getting started with PP CC, I downloaded the trail version since I couldn't work with the XAVC in my other software. I am apparently just using the default settings. |
#311 |
I have tried importing and dragging all flavours of XAVC files into various NLEs. With the 230mbit XAVC-I MXF files from the F5 / F55 I have no issues. Also no issues with the 8-bit XAVC-S files that are wrapped as MP4s such as those from the Sony A7S. Where the problem appears to lie for some of us is with the newer 50-mbit XAVC-L MXF files from the PXW-X70. It is these Long GOP files that are proving very hard to read. I have tried reading them with the latest update of Premiere CC and Avid on Mac and Vegas and Avid on PC and all to no avail.
Upon analysis of earlier XAVC MXF files I find that all previous iterations have been written with Sony's writing and library application called 'Sony util 1.0' Whereas these newer XAVC-L 50-mbit MXFs from the X70 have been written by a new Sony writing and library application that I haven't seen before and it's called 'Sony mem 2.0' Why Sony has made changes to the writing and library app is unknown. I guess they have a good reason for doing so. There are other significant changes in the file structure of the two MXF flavours such as CABAC and Format_setting_wrapping as can be seen from the attached JPEGs of the file info’s. Until such time as Sony releases the details for these proprietary libraries I don't see any hope of any resolution coming quickly. By all accounts Edius manages to read these files with no issues. Maybe they have a hot line to Sony's software team. It does make we wonder if this issue is going to appear with the release of all the new XAVC-L MXF capable cameras such as the PXW-X160 / 180 / 200. This could get interesting if it's not sorted pretty quickly. Chris Young CYV Productions Sydney Last edited by Christopher Young; October 9th, 2014 at 09:28 AM. Reason: add info |
#312 |
Apologies if these questions have been dealt with elsewhere in this gigantic thread; I'm coming in late:
*) Does the camera support 1080p60 in XAVC 50Mbit? The specifications here suggest not: Sony X70 Page ...while the specifications here suggest so: Sony X70 PDF Brochure Similarly, B&H omits any mention of 1080p60 XAVC. Seems odd that the camera wouldn't inherit all the HD modes of its cheaper siblings, but... *shrug* Which is it? *) Is the 4:2:2 XAVC from this camera supported by Premiere CS5.5? I've had no trouble with the 4:2:0 8-bit stuff from the CX900 and AX100, but a line has to be crossed at some point, I suppose. :)
Software Engineer, Video Hobbyist -- Sony FDR-AX100, HDR-CX12, Miller DS10/Solo, Premiere CS5.5, DYMO DiscPainter, 2010 Mac Pro 3.33GHz 6c |
#313 | ||
I cannot answer the second question. |
#314 | |
Thanks! Aaron
#315 | |
XAVC HD : MPEG-4 AVC/H.264 4:2:2 Long profile So my understanding is all the XAVC, regardless of the frame rate will be 4:2:2. The file extensions are .MXF |
