#1921 |
Re: Sony FDR-AX100
I thank you but I have solved my problem sending t efile to a private video laboratory.
A lonesome traveler looking for lost tribes around the world: https://www.youtube.com/channel/UCdv...DrZCaaw/videos |
#1922 |
Re: Sony FDR-AX100
HandBrake and Sony AX100.
I use Sony AX100. I don't know HandBrake very well and I'd like to ask a question: I have just created an unconpressed AVI (YUY2) 4K file and now I'd like to create a new file 4K file with HandBrake. I'm insecure if In Framerate (FPS) Option I have to choose 30 or if it is better more than 30. I'd like to get a very good video. I attach a pic. Thanks for some info. Thanks
#1923 |
Sony FDR-AX100 three years later
Error, moderator please delete.
#1924 | |
Re: Sony FDR-AX100
As you know from another post you kindly replied to I just bought an FDR-AX100 on amazon for 1200 EUR. With the advantage of hindsight, what do you think of your words at the time, three years ago? Has the technology evolved so much? Not that I would care if my recently acquired camera is already obsolete, because it is good enough for my needs, but I would appreciate your thoughts on the matter. JA |
#1925 |
Re: Sony FDR-AX100
Interesting question Jaime!
Considering that the AX100 is still in the current Sony lineup, that says quite a lot... I was expecting 60p to become "standard" rather more rapidly than it has... still waiting, 5 years looking like the timeline, as 3 has pretty well gone (unless you count the GH5... tempting, but I'm not ready to completely switch systems!). I'm still running a "cheap" Seiki TV, had to make sure it had the ability to turn off motion compensation (firmware update), it's supposed to handle 60p, but I've found the laptops that "should" drive it are hampered by the Intel video chipset that somehow just won't go over 30p, even if they have NVIDIA chipsets available... I'm shooting RX10M2 and M3, which use a similar sensor to the AX100, just a generation or two later, with some minor improvements. Aside from the form factor ("still" vs. "video" camera shape), in my mind they are just a "camera", and capture what I want quite well. The results look stunning, I'm comfortable with the technology and how to get what I want out of it, so even if I have to wish that we had "better", I can't complain! |
#1926 |
Re: Sony FDR-AX100
Adriano...select the "same as source" option for framerate.
Dave, 60p at FHD was and is reserved for basically "home video cameras", as 1080 60p is not a broadcast standard or delivery format. Given that 4K production is mostly for 24p TV shows, and the need for HDMI 2.0 to pass 4k 60p, and you end up waiting for the infrastructure of cheapness to trickle down. I think 60p is the PERFECT framerate, as it works for 720p60, for 1080p60i, and perfectly fine doubling up on 30p 4K stuff. I have never liked 30p...either looks smeared at 1/30 shutter or jittery at 1/60 shutter...a bastard framerate. Paul |
#1927 | |
Re: Sony FDR-AX100
Last week I charged it again and there was no issue at all with it. I know no Lithium ion battery that can do that, stay 3 years and a half without recycling and still work. |
#1928 | |
Re: Sony FDR-AX100
#1929 |
Re: Sony FDR-AX100
Be aware that when using this WB offsetting, you will create an offset to the AWB/ATW system as well. It is a feature/function best reserved for MANUAL kelvin or dialing in after you set an A or B or whatever it's called on the AX100/CX900 series.
Paul |
#1930 |
Re: Sony FDR-AX100
Dear friends, I post here because all you gave me very good suggestions in past time.
I'm a lonely traveller and I'm using a Sony AX100 for my ethnic documentaries around the world. I shot in 4K ans I make UHD videoediting. The next month I'd like to replace my Sony AX100 with Panasonic GH5. Does anybody use GH5 and Sony AX100? Is there a very improvement in the video quality really? I'm afraid to make an error to buy GH5 for my documentaries. I'm not expert in cameras and I'm afraid to make an error because a camera isn't so immediate and fast like a videocamera to shot. Can you give me some info please? May be it possible to make a good documentary with a GH5 in the bush or in the forest? I mean about its handling, etc. Has GH5 a better steadyshot than Sony AX100? Is it very hard to use the zoom with GH5? I know GH5 comes with a 12-60 mm object. Can you tell me how much is a 12-60 mm focal compared to a videocamera focal (precisely)? Thanks
#1931 |
Re: Sony FDR-AX100
Hi, Ax100 newbie here. My time readout says that I have 4 hours and 30 minutes of recording time left @ 4K. Someone said that the remaining time display was “optimistic” but I did not ask him to quantify that. How do I relate the remaning time display with how much recording time is actually left? I’m using a 128G card.
Thanks |
#1932 |
Re: Sony FDR-AX100
The ax100 doesn't guess what remaining recording time is, it is what is says and it's correct, the only thing that can deviate is remaining battery life.
#1933 |
Re: Sony FDR-AX100
Thanks!! Simple math should have told me that.
#1934 |
Re: Sony FDR-AX100
Why does the ND filter symbol blink when the switch is in any position other than off when in manual? it actually says “ND off”. This confuses me, because I think the filter is on.
#1935 |
Re: Sony FDR-AX100
It is telling you to switch the filter to OFF as it does not need it to control exposure. If you have the filter in any position other than OFF then it is selected for some value ? If you need the filter it will indicate which value to choose to get within exposure range. You can of course ignore it and make your own decisions.
